Padding at the end of models .ini files
- ethernode
13 Sep 2015 15:35 - 13 Sep 2015 15:42 #37716
by ethernode
Padding at the end of models .ini files was created by ethernode
Newbie here; i noticed that there is some zero padding in the end of ini files that is apparently being added by deviationtx itself when editing a model; while i don't really care, it makes gedit not happy at all (trying to guess the character encoding of this null padding). Out of curiosity, why is it happening ? Is there any way to avoid it ?
$ hexdump -C inductrix_indoor.ini
00000000 6e 61 6d 65 3d 49 6e 64 75 63 74 72 69 78 20 69 |name=Inductrix i|
00000010 6e 64 6f 6f 72 0a 6d 69 78 65 72 6d 6f 64 65 3d |ndoor.mixermode=|
00000020 41 64 76 61 6e 63 65 64 0a 69 63 6f 6e 3d 49 4e |Advanced.icon=IN|
00000030 44 55 43 54 2e 42 4d 50 0a 5b 72 61 64 69 6f 5d |DUCT.BMP.[radio]|
00000040 0a 70 72 6f 74 6f 63 6f 6c 3d 44 53 4d 58 0a 6e |.protocol=DSMX.n|
00000050 75 6d 5f 63 68 61 6e 6e 65 6c 73 3d 36 0a 74 78 |um_channels=6.tx|
00000060 5f 70 6f 77 65 72 3d 31 35 30 6d 57 0a 0a 5b 70 |_power=150mW..[p|
00000070 72 6f 74 6f 63 6f 6c 5f 6f 70 74 73 5d 0a 54 65 |rotocol_opts].Te|
00000670 54 78 50 6f 77 65 72 3d 31 30 32 2c 37 0a 71 75 |TxPower=102,7.qu|
00000680 69 63 6b 70 61 67 65 31 3d 43 68 61 6e 6e 65 6c |ickpage1=Channel|
00000690 20 6d 6f 6e 69 74 6f 72 0a 00 00 00 00 00 00 00 | monitor........|
000006a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00003000 00 00 00 00 00 00 00 00 00 0a 00 00 00 00 00 00 |................|
00003010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00003ff0 00 00 00 00 00 00 00 00 00 00 00 00 00 0a 00 0a |................|
00004000
Last edit: 13 Sep 2015 15:42 by ethernode.
- greenfly
14 Sep 2015 16:13 #37764
by greenfly
Replied by greenfly on topic Padding at the end of models .ini files
This is normal.
I could not find a way for Gedit to open them directly without the warning. It depends on the editor... Notepad++ in Windows does not have a problem with the trailing nulls.
I actually solved the issue with my utility here . It trims the nulls prior to opening the INI file.
- ethernode
15 Sep 2015 10:26 #37779
by ethernode
Replied by ethernode on topic Padding at the end of models .ini files
Okay thanks.
Time to create page: 0.625 seconds
- Padding at the end of models .ini files
