Bug? Changing icons from the menu causes crashes.
- serum
11 Oct 2015 15:49 #38741
by serum
Bug? Changing icons from the menu causes crashes. was created by serum
Using 4.0.1, devo 10.
First off; thanks for enabling these features from the devo10. Amazing work.
When an icon is placed in the modelico folder (H8.bmp) and this icon is changed from the transmitters menu, (model menu > model setup > Icon) and another icon is selected than the standard ones available, the transmitter crashes. Unless you rename this icon to plane.bmp it works like a charm. While browsing to that H8.bmp icon, it also publishes a wrong name, it shows up as _MULT~1.bmp. Once selected, it crashes. Friend of mine is experiencing the same issue with his Devo.
If this icon is defined using an edit tool in the model.ini and the original name is being used (H8.bmp), and the H8.bmp file is put in the modelico folder, it works like it should. Right icon is shown in the menu and the name h8.bmp can be used).
- beardyman
11 Oct 2015 17:06 - 11 Oct 2015 17:07 #38743
by beardyman
Replied by beardyman on topic Bug? Changing icons from the menu causes crashes.
I can confirm that this bug has been present for a long time, and is still in the latest nightlies. I'm using both Devo 7e and 10. I have gotten around it by editing the model files directly, and it's only a minor annoyance, but it would be nice if it could be fixed.
Last edit: 11 Oct 2015 17:07 by beardyman. Reason: Spelling mistake
- richardclli
12 Oct 2015 00:10 #38750
by richardclli
Replied by richardclli on topic Bug? Changing icons from the menu causes crashes.
Is there any issue in the issue tracker? I will try to see if I can fix this.
- richardclli
12 Oct 2015 04:10 #38753
by richardclli
I tried it out in the emulator, but I cannot reproduce this bug. Have you tried it in the emulator?
- Daryoon
12 Oct 2015 05:20 #38756
by Daryoon
Replied by Daryoon on topic Bug? Changing icons from the menu causes crashes.
I've only seen corrupted model icon causing a reboot. If you remove or replaced the bad model icon, it solves the problem.
- beardyman
12 Oct 2015 15:03 #38760
by beardyman
I just tried removing all my extra icons, leaving only the stock icons, freshly copied from a new install, but the bug remains on my Devo 7e, using v4.0.1-a5a424c.
- beardyman
12 Oct 2015 15:26 #38761
by beardyman
I can't replicate the bug in the emulator.
- kahuna001
05 Feb 2016 00:42 #42606
by kahuna001
Replied by kahuna001 on topic Bug? Changing icons from the menu causes crashes.
I don't know if anyone figured out the bug but I think it is because of OS X putting in ._XXX.bmp files.
I open terminal and cd /modelico folder
rm ._*.bmp which removed all the extra files.
and it works for me now. I can browse all the icons. Make sure it is 8.3 format.
- beardyman
05 Feb 2016 00:55 #42607
by beardyman
I think you've figured it out! I am using OS X. I just followed your instructions and now I can finally change icons through the GUI. Thanks!
- Nelicopter
13 Jun 2017 12:50 #62966
by Nelicopter
Replied by Nelicopter on topic Bug? Changing icons from the menu causes crashes.
I've been having that same issue, I'd just like to thank Kahuna for helping me out, works a charm.
Time to create page: 0.049 seconds
- Bug? Changing icons from the menu causes crashes.
