Reinstalling Walkera Devo 7e firmware
29 Oct 2015 23:13 #39353 by mzbeg
Hi, this question might have been answered before, but I could not find it. The reason I want to go back to the original firmware, because its manual is more detailed and comprehensive than the Deviation manual. Please do not take me wrong. As I am totally new to this modern TX, I have to relearn many things. After I have mastered it then I will go back to deviation 4.01 and modify my TX.
I have bought the 7e 2nd hand, already has Deviation on it. I have been looking for the firmware every where but I could not find it.
Thanks for your help.
29 Oct 2015 23:35 #39354 by RedSleds
Replied by RedSleds on topic Reinstalling Walkera Devo 7e firmware
Official Walkera firmware is here: >>> walkera.com/en/upload/radio/ <<<
www.walkera-fans.de has some more up to date firmware for certain radios than even Walkera has listed on their official site. You can find it as a zip file under >Downloads(far right column)>Sender>Devo7E
29 Oct 2015 23:43 #39355 by mzbeg
Replied by mzbeg on topic Reinstalling Walkera Devo 7e firmware
Thank you very much. I visited the german site, could not find any firmware for 7E though.
29 Oct 2015 23:50 #39356 by mzbeg
Hi, perhaps you can help me here. I download the zip file, and there are two file in it, one is "DEVO-7E Fw v0.2.dfu" and the other is "DEVO-7E Lib v0.1.dfu". Which one should I use, or do I use the 2nd one first and the first one after it, becuase the 2nd is bigger than the first.
29 Oct 2015 23:53 - 29 Oct 2015 23:58 #39357 by RedSleds
I'm not sure, I have a DEVO 10.
I would assume that you flash the F/W first, and then load the library. ......but as I said, not sure about that.
Last edit: 29 Oct 2015 23:58 by RedSleds.
30 Oct 2015 03:21 - 30 Oct 2015 03:34 #39359 by Arnold
Replied by Arnold on topic Reinstalling Walkera Devo 7e firmware
RedSleds is right.
From the FAQ:
"HELP! I can't put the original firmware back!
First take a deep breath. I haven't seen a single case that we couldn't resolve. Next go get a new copy of the firmware from Walkera. We need to ensure you are starting with a clean firmware so even if you are sure you've just done this, do it again.
Next use the Walkera DFusE tool to 'Upgrade' (do NOT use 'Upload'!) the firmware onto your Tx. Go to the 'Library' tab, and again 'Upgrade' (NOT 'Upload') the library. Power off the Tx and you should be good to go."
An alternative to the Walkera DFusE tool is the Deviation java (cross platform) installer (DeviationUpload-0.8.0.jar) which you can get from
deviationtx.com/downloads-new/category/161-dfu-usb-tool
Using that tool, you can install the .zip file directly without decompressing it. The tool takes care of putting everything in the right place at the right time.
If you experience driver issues in Windows, try using the DFU USBDrv Installer-1.1 tool from the same source location.
Last edit: 30 Oct 2015 03:34 by Arnold.
30 Oct 2015 16:00 #39372 by mzbeg
I download the latest firmware as well as "DeviationUpload", but how do you use it. How do you install it on Windows 7 64bit ?
30 Oct 2015 20:09 #39380 by mzbeg
In DfuSe the firmware file ""DEVO-7E Fw v0.2.dfu" is not recognised. I get a message "The file does not have correct format". What am I doing wrong ? Please help !!!!
30 Oct 2015 20:57 - 31 Oct 2015 03:07 #39383 by Arnold
mzbeg wrote: I download the latest firmware as well as "DeviationUpload", but how do you use it. How do you install it on Windows 7 64bit ?
The file, "Deviation Uploader-0.8.0.jar" is a Java program or application or "app" in today's parlance. As such, you don't install it. It simply resides on your hard drive somewhere of your choice. Put it on the desktop or in a folder somewhere where you can find it in the future. In order to use this Java app, you need to have the Java Runtime Environment installed on your computer. You can get that from Oracle, the developer of Java:
java.com/en/download/
Download to your computer and install it. Then follow these steps:
- Connect your Devo directly to your PC using the USB cable. Do not use a USB hub.
- Double-click the icon for the Java application, "Deviation Uploader-0.8.0.jar" to run it.
- On the Devo, hold down the Ext button and turn on the Tx.
- In a few moments, your Devo should show up as the Transmitter at the top in the installer window
- The "Install/Upgrade" tab should be active
- Click the "..." button on the Firmware line.
- Browse to the location of the Zip file for the Walkera firmware .zip file you downloaded and click on "Open".
- Check the box for "Format" if it is not ghosted.
- Click the "Install/Upgrade" button
- Agree to format the drive if prompted.
- Wait till the installer finishes.
This procedure should overwrite anything you've done previously and put things right.
Last edit: 31 Oct 2015 03:07 by Arnold.
30 Oct 2015 23:17 #39387 by mwm
Replied by mwm on topic Reinstalling Walkera Devo 7e firmware
Arnold wrote: - The "Install/Upgrade" tab should be active
Doesn't he also need to install the library? Or does the Deviation Uploader do that automatically in this case?
31 Oct 2015 02:51 #39394 by Arnold
mwm wrote: Doesn't he also need to install the library? Or does the Deviation Uploader do that automatically in this case?
The Deviation uploader does it automatically (automagically!) Very convenient.
31 Oct 2015 06:01 #39397 by mzbeg
Thank you all for your help. Where I got stuck is when DeFusE says "The file does not have correct format", I think I need the original File, what I have and trying upload is just the update to the original firmware.
When you go to Walkera site, it seems they have never heard of Devo7E TX, other sites which point to the firmware are all dead.
31 Oct 2015 06:41 - 31 Oct 2015 06:43 #39400 by RedSleds
walkera-fans.de/downloads/
After you download, you have to extract the .zip file to get the .dfu files.
Last edit: 31 Oct 2015 06:43 by RedSleds.
31 Oct 2015 13:16 #39411 by mzbeg
I have indeed download the file from the German site, and I unzipped it and this is what I got, two files :
DEVO-7E Fw v0.2.dfu 91 kb
DEVO-7E Lib v0.1.dfu 260 kb
to these files DeFusE says "The file does not have correct format",
31 Oct 2015 13:43 #39413 by TomPeer
Replied by TomPeer on topic Reinstalling Walkera Devo 7e firmware
I just tried these file and they work fine.
Whitch dFuse file did you use. You can download the correct file at the same site. You find it under Tools.
31 Oct 2015 13:56 #39415 by mzbeg
I just downloaded "Walkera Dfuse USB Upgrade Tools 2.31.exe", previously I was using Version 2. I tried it and still I am getting the same message "The file does not have correct format",
31 Oct 2015 14:13 #39416 by TomPeer
At what point do you get that message, when you load the dfu file in dfuse program or after you hit the upgrade button.
I did not do the upgrade part sinds i do not want this program in my devo 7e, but when this is were you got the message than i will try.
31 Oct 2015 14:15 #39417 by mzbeg
The moment I load the firmware file. It is in red.
31 Oct 2015 14:22 #39418 by TomPeer
I use exact the same prorame and files you use.
I try to reproduce your problem. I can load the dfu file without any problem. When i ty to load the zip file i get the same message.
Is it possible you try to load the zip file?
other wise i would not know why it does not work for you.
31 Oct 2015 15:07 #39419 by mzbeg
This time I did extract it properly, DefE did recognize it. I upgraded it. After switching off and on again I geting this message from the TX. "Throtle Stuck"
Time to create page: 0.175 seconds
