Reinstalling Walkera Devo 7e firmware
- TomPeer
31 Oct 2015 15:20 - 31 Oct 2015 16:30 #39421
by TomPeer
Replied by TomPeer on topic Reinstalling Walkera Devo 7e firmware
calibrate the sticks.
- Transmitter menu
-Transmitter config
- Sticks calibrate.
EDIT:
Sorry this was for deviation software.
But the official walkera software also has a calibration option somewhere.
- Transmitter menu
-Transmitter config
- Sticks calibrate.
EDIT:
Last edit: 31 Oct 2015 16:30 by TomPeer.
31 Oct 2015 16:07 #39422
Replied by FDR on topic Reinstalling Walkera Devo 7e firmware
...and also check which transmitter mode you are in, because it is often in Mode 1 after the fw upgrade.
- mzbeg
31 Oct 2015 16:40 #39425
by mzbeg
Replied by mzbeg on topic Reinstalling Walkera Devo 7e firmware
I successfully installed Deviatgion 4.0.1, but again when I tried Walkera Firmware, first Firmware file and then Lab. File, switched off TX, pressed ENT to go into USB mode, I get the same message "Throtle Stuck".
- mzbeg
31 Oct 2015 16:43 #39426
by mzbeg
The TX is in mode two from factory. How can you calibrate sticks, when you can not enter 7E software on TX.
- TomPeer
31 Oct 2015 17:18 #39427
by TomPeer
Stock walkera firmware does NOT have a usb mode.
- TomPeer
31 Oct 2015 17:32 #39429
by TomPeer
OK. I went for it. I also installed the walkera software. first fimware and then the library.
When you firs turn on the transmitter, you get the message: throttle stick.
The transmitter is in mode 1 and assumes the right stick is the throttle stick.
Push the right stick down and the transmitter works.
If you use mode 2 then you have to set the transmitter to that mode first.
push the ENT button and go to system menu.
scroll down to stick mode and push it.
now set mode 2.
It should work now.
now set mode 2.
It should work now.
- mzbeg
31 Oct 2015 17:33 #39430
by mzbeg
It means that once you install Deviation on DEVO 7E, you can not go back to the official firmware.
- TomPeer
31 Oct 2015 17:40 - 31 Oct 2015 17:41 #39432
by TomPeer
what are you talking about????
I just told you i just did and it works fine.
Just set the transmitter to mode 2 after you reinstalled the walkera software.
FDR also told you this before.
Last edit: 31 Oct 2015 17:41 by TomPeer.
- mzbeg
31 Oct 2015 17:47 #39433
by mzbeg
SUCCESS !!!! Thank you very much. In Deviation software I changed from Mode 2 to Mode 1. I uploaded the firmware first and then the Lib. Switched off and on again. I got the same message "Throtle stuck". I moved the right stick and every thing was ok.
- TomPeer
31 Oct 2015 17:50 #39434
by TomPeer
- smartpui
04 Jun 2018 09:43 #69531
by smartpui
Replied by smartpui on topic Reinstalling Walkera Devo 7e firmware
It's very easy to reinstall Devo7e firmware.
1. Download Devo7e firmware from the above links or walkera-fans.de/downloads/
2. you'll got 2 file when unzip : 1.DEVO-7E Fw v0.2.dfu (91 kb) 2. DEVO-7E Lib v0.1.dfu (260 kb)
3. Connect USB wire between Devo7e and PC and press EXT+Turn on TX
4. open the DfuseUSB upgrade tool on yr PC (window for upgrading file to yr TX)
5. next select file 1.DEVO-7E Fw v0.2.dfu and enter for upgrade
6. then select file 2.DEVO-7E Lib v0.1.dfu (260 kb) and enter for upgrade
7. after finished Turn off TX and Turn on TX again... that's it. You'll get the original Devo7e firmware back...Good Luck
Time to create page: 0.129 seconds
- Reinstalling Walkera Devo 7e firmware
