Frsky module install in Devo 10 Help
11 Nov 2015 22:17 - 12 Nov 2015 03:26 #39954 by Tomcor
Frsky module install in Devo 10 Help was created by Tomcor
I am looking to install a single frsky module in my Devo 10.
I have two different modules to use. Xl2500-d03 or cc2500 PA.
Which module would be better to install for long range?
I will be soldering a pigtail antenna connector for using an external antenna.
What is the correct wiring diagram for this install? I have alot of different wiring info saved. Just what to use the correct one for the new version of Deviation.
I have installed dual modules in my 7E so i do have experience with this.
Last edit: 12 Nov 2015 03:26 by Tomcor.
12 Nov 2015 05:35 #39965 by mwm
Replied by mwm on topic Frsky module install in Devo 10 Help
The definitive docs on module installation are PB's here: bitbucket.org/PhracturedBlue/deviation/wiki/ModuleList THey are actively maintained and updated. Follow it for wiring.
Time to create page: 0.166 seconds
