Empty hardware.ini
29 Nov 2015 19:07 #40484 by barrymossel
Empty hardware.ini was created by barrymossel
I just did the 3x2 switch mod on my new Devo 7E. I activated the mod in the hardware.ini and everything actually works. But when I go to USB mode, upload/update a model and restart sometimes the hardware.ini gets corrupt and the extra switches don't work. After going to USB mode and reuploading the hardware.ini (with mod activated) everything works again.
Why is my hardware.ini going empty?
29 Nov 2015 19:53 #40486 by Deal57
Replied by Deal57 on topic Empty hardware.ini
Did you format the USB drive at some point? Is your 7e battery fresh? These are two of the most common failures.
04 May 2017 20:48 #62008 by teoplays
Replied by teoplays on topic Empty hardware.ini
Hi,I'm new to the forum. I have the same problem.
I have a Devo 7e, 3in1 module and two switch 3 positions.
I connected to USB and after loading model.ini, hardware.ini has disappeared.
The problem is I do not have a copy. I didn't know its needed, and the friend who installed me did not let me know :(
How can I fix it? Thanks
Time to create page: 0.376 seconds
