nRF24L01+ module
- Gramps50
02 Dec 2015 15:55 #40563
by Gramps50
Gramps
nRF24L01+ module was created by Gramps50
Just purchased a Devo 10, I will be using it presently to fly my Syma X5C-1 & Syma X11. I understand that I need a nrf24l01+ added to the Devo 10. When looking for the module it gets pretty confusing.
Is this the correct module? www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html also saw one on eBay that looked just like it with out the antenna, which I'm thinking will be needed.
Gramps
- bmw111
02 Dec 2015 16:30 #40564
by bmw111
Replied by bmw111 on topic nRF24L01+ module
Yes, that is the correct module. I have it in my Devo 10 and it works great. Order a few in case you have problems installing it. I didn't have any issues -- it's a pretty straightforward install -- but it can be easy to bodge up if your soldering skills are rusty.
- Gramps50
02 Dec 2015 23:09 #40567
by Gramps50
Gramps
Replied by Gramps50 on topic nRF24L01+ module
Might as well get the A7105 module while I'm at it. This the one I need?
www.banggood.com/A7105-Wireless-RF-2_4GH...Module-p-909404.html
Gramps
03 Dec 2015 04:45 #40570
Replied by mwm on topic nRF24L01+ module
That one works. The best way to connect a better and/or external antenna seems to be to replace the wire antenna with a uFL connector. You may want to order those and the appropriate uFL cable at the same time, as they tend to get pricey unless they're shipped from China.
- Vandal
12 Jan 2016 18:19 - 12 Jan 2016 18:31 #41680
by Vandal
Replied by Vandal on topic nRF24L01+ module
I assume the same applies to the 7E?
This
is the correct set for the Devo 7E to control the Syma X5C-1 as well?
Last edit: 12 Jan 2016 18:31 by Vandal.
Time to create page: 0.375 seconds
- nRF24L01+ module
