nRF24L01+ module
02 Dec 2015 15:55 #40563 by Gramps50
nRF24L01+ module was created by Gramps50
Just purchased a Devo 10, I will be using it presently to fly my Syma X5C-1 & Syma X11. I understand that I need a nrf24l01+ added to the Devo 10. When looking for the module it gets pretty confusing.
Is this the correct module? www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html also saw one on eBay that looked just like it with out the antenna, which I'm thinking will be needed.
Gramps
02 Dec 2015 16:30 #40564 by bmw111
Replied by bmw111 on topic nRF24L01+ module
Yes, that is the correct module. I have it in my Devo 10 and it works great. Order a few in case you have problems installing it. I didn't have any issues -- it's a pretty straightforward install -- but it can be easy to bodge up if your soldering skills are rusty.
02 Dec 2015 23:09 #40567 by Gramps50
Replied by Gramps50 on topic nRF24L01+ module
Might as well get the A7105 module while I'm at it. This the one I need? www.banggood.com/A7105-Wireless-RF-2_4GH...Module-p-909404.html
Gramps
03 Dec 2015 04:45 #40570 by mwm
Replied by mwm on topic nRF24L01+ module
That one works. The best way to connect a better and/or external antenna seems to be to replace the wire antenna with a uFL connector. You may want to order those and the appropriate uFL cable at the same time, as they tend to get pricey unless they're shipped from China.
12 Jan 2016 18:19 - 12 Jan 2016 18:31 #41680 by Vandal
Replied by Vandal on topic nRF24L01+ module
I assume the same applies to the 7E? This is the correct set for the Devo 7E to control the Syma X5C-1 as well?
Last edit: 12 Jan 2016 18:31 by Vandal.
Time to create page: 0.502 seconds
