Devo 10 running Deviation wont save new values
- steadfast4life
08 Dec 2015 19:55 #40710
by steadfast4life
Devo 10 running Deviation wont save new values was created by steadfast4life
I recently entered the realm of deviation with a new Devo 10. Deviation works great, binds well to DSMX RX as I wanted. Bought all the goodies for the multimodule which I have started building. My problem is that the Devo 10 wont save any new values like my DX6 and FrSky Taranis. I've set the timer 20 times but it won't save it. The next time I turn on the transmitter, the timer value is reset to 0. If I set up dual rates, the Devo doesn't remember them the next time I turn on the transmitter. It doesn't seem to matter the value be it rates, internal battery monitor, timer or virtually any value past basic model setup, the transmitter wont save the value. Is there a trick or do I have a dud of a radio? Thanks for any help you can provide.
- Gramps50
09 Dec 2015 03:13 #40736
by Gramps50
Gramps
Replied by Gramps50 on topic Devo 10 running Deviation wont save new values
I'm going to take a shot in the dark here, I still waiting for my Devo 10 to arrive. Almost sounds to me that one or all of you config files is set to Read Only this would prevent your Devo 10 from writing yo it.
Gramps
- Deal57
09 Dec 2015 03:27 #40737
by Deal57
Replied by Deal57 on topic Devo 10 running Deviation wont save new values
The first time you loaded Deviation did you format the USB drive or just load up the files? If the USB part of memory isn't right, it may not write or read files correctly.
And if it's not that, can you post your tx.ini file and a copy of your model.ini? Are you using Notepad++ (not window's notepad) to edit files or are you editing the in the GUI?
- steadfast4life
02 Feb 2016 22:21 #42530
by steadfast4life
Replied by steadfast4life on topic Devo 10 running Deviation wont save new values
I found a solution to this problem. I tried using a 2s life battery to power the tx instead of the nimh batteries. Problem was that when the voltage gets too low, no new values will be saved. I used a 3s life battery and all is well.
- Arnold
02 Feb 2016 23:05 #42532
by Arnold
Replied by Arnold on topic Devo 10 running Deviation wont save new values
Good job!
Time to create page: 0.507 seconds
- Devo 10 running Deviation wont save new values
