Unable to locate hardware.ini file
15 Dec 2015 01:51 #40938 by arkennedy75
Unable to locate hardware.ini file was created by arkennedy75
I'm using Devation version 4.0.1 on Devo 7E. After navigating through all the folders on the 7E I'm unable to find the hardware.ini file. What am I missing?
15 Dec 2015 02:03 #40939 by Deal57
Replied by Deal57 on topic Unable to locate hardware.ini file
Hardware.ini was introduced after the release of 4.0.1. That release used the rx.ini file to set up the additional modules. Post-release the team decided to use a new hardware.ini file to manage hardware modifications. If you run the nightly builds you'll find the hardware.ini in the root folder of the USB drive, alongside tx.ini.
15 Dec 2015 02:08 #40940 by arkennedy75
Replied by arkennedy75 on topic Unable to locate hardware.ini file
Thanks for the response. I'm not seeing the rx.ini file either. Any suggestions?
15 Dec 2015 02:09 #40941 by Deal57
:blush: aw jeezz... That should have been TX.ini. There isn't any rx.ini. Sorry :S
Time to create page: 0.419 seconds
