A7105 jumper wire clarification
- Fyathyrio
28 Dec 2015 21:28 #41216
by Fyathyrio
A7105 jumper wire clarification was created by Fyathyrio
I'm about to install the A7105 chip into my Devo 7e, and wanted clarification on which terminals get jumpered. I'm running an older version of Deviation, v4.0.1-95fd5f0 if that helps, and already have the NRF module installed.
The reason I'm confused is based on this picture from PhracturedBlue's wiki article.
Do I go with 4.0.1 and earlier version, with 8->GND and 9->3.3V. or with after 4.0.1 option with 6->9 and 7->8? (Pins numbered 1 to 9, left to right)
Thanks for the help
Thanks for the help
- RedSleds
28 Dec 2015 21:51 #41218
by RedSleds
Replied by RedSleds on topic A7105 jumper wire clarification
Nightly Builds are considered "After 4.0.1"
- Fyathyrio
29 Dec 2015 04:21 #41234
by Fyathyrio
Replied by Fyathyrio on topic A7105 jumper wire clarification
Thanks for clearing that up...one other question now.
When I set up hardware.ini I initially set as has_PA = 1, and didn't work. After setting PA to 0 it works and binds...is this normal for this type module? It's the 500m range one with shield that's recommended, not one pulled from a toy Tx.
Thanks again
Thanks again
Time to create page: 0.135 seconds
- A7105 jumper wire clarification
