Source for Devo 10/8s replacement RF module?
04 Jan 2016 16:59 #41377 by NHdude001
Thinking about replacing the RF module in my Devo 7E with the full-power module from the larger transmitters rather than fooling around with the range mod. But, I have had no luck locating this module. Might anyone know where it might be available?
04 Jan 2016 22:32 #41382 by mwm
Check the module list in the wiki: bitbucket.org/PhracturedBlue/deviation/wiki/ModuleList
Any of the replacements should work, and since you've got to wire it in anyway, there's no reason to stick with the one Walkera chose.
05 Jan 2016 17:15 #41406 by NHdude001
Replied by NHdude001 on topic Source for Devo 10/8s replacement RF module?
Thank you! So, any CRYF 6936 module will work then? Yep, totally newbie here :-)
06 Jan 2016 01:41 #41418 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Source for Devo 10/8s replacement RF module?
How does range and telemetry compare with those other modules? Doesn't seem to be much associated info?
Time to create page: 0.129 seconds
