Source for Devo 10/8s replacement RF module?
- NHdude001
04 Jan 2016 16:59 #41377
by NHdude001
Source for Devo 10/8s replacement RF module? was created by NHdude001
Thinking about replacing the RF module in my Devo 7E with the full-power module from the larger transmitters rather than fooling around with the range mod. But, I have had no luck locating this module. Might anyone know where it might be available?
04 Jan 2016 22:32 #41382
Replied by mwm on topic Source for Devo 10/8s replacement RF module?
Check the module list in the wiki:
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleList
Any of the replacements should work, and since you've got to wire it in anyway, there's no reason to stick with the one Walkera chose.
- NHdude001
05 Jan 2016 17:15 #41406
by NHdude001
Replied by NHdude001 on topic Source for Devo 10/8s replacement RF module?
Thank you! So, any CRYF 6936 module will work then? Yep, totally newbie here
- RoGuE_StreaK
06 Jan 2016 01:41 #41418
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Source for Devo 10/8s replacement RF module?
How does range and telemetry compare with those other modules? Doesn't seem to be much associated info?
Time to create page: 0.302 seconds
- Source for Devo 10/8s replacement RF module?
