USB wont connect
- hogan
16 Jan 2016 17:16 #41823
by hogan
USB wont connect was created by hogan
Have the Devo 7e. Installed 2 modules, flashed it with 4.0.1, put new models in and everything is all fine and dandy. Over a few months, I got rid of some helicopters and quads and got newer ones and went back to update the models in my Tx and tried to connect it to the PC and the computer isn't recognizing the Tx. I tried on 3 computers and nothing. The cable is fine. The Tx is showing the USB on the screen but nothing is happening on the computer end.
As you can imagine, frustration is starting to set it.
Any ideas?
Any ideas?
- Cereal_Killer
16 Jan 2016 18:11 #41828
by Cereal_Killer
Replied by Cereal_Killer on topic USB wont connect
Have you went into your hardware manager and conformed the computer is seeing the devo and loading the appropriate drivers for it?
You're using the ENT button for USB drive mode (NOT bootloader / DIY mode)?
- hogan
16 Jan 2016 18:25 - 16 Jan 2016 20:13 #41831
by hogan
Replied by hogan on topic USB wont connect
I am in USB drive mode, shows the USB symbol on the Tx.
I did go to hardware manager but not sure where to go after that or what to look for.
EDIT- The computer didn't find anything in the hardware manager. USB ports are working fine.
Last edit: 16 Jan 2016 20:13 by hogan.
- hogan
16 Jan 2016 21:29 #41834
by hogan
found problem #1- The USB port on the TX was not making a good connection, and when I plugged the cable back in the last time, she broke! oh boy.
Time to create page: 0.109 seconds
- USB wont connect
