Dev 7e Module mod gone bad
23 Jan 2016 18:17 #42129 by Dante1
Dev 7e Module mod gone bad was created by Dante1
Hello everyone,
I have a Devo 7e with the range mod. I tried to bind a DSM2 RX and no go. The LED constantly blinks as if it never communicated. I know it's not the ID because it would go through the bind process and then the LED would go off. I read somewhere that I can replace the module with a Devo 8 module. Is this correct? Where can I find one?
Thanks in advance.
27 Jan 2016 16:40 #42274 by anansi22
Replied by anansi22 on topic Dev 7e Module mod gone bad
Banggood.com
27 Jan 2016 16:44 #42275 by Dante1
Replied by Dante1 on topic Dev 7e Module mod gone bad
anansi22 wrote: Banggood.com
Can you be a bit more specific? I searched Banggood and can't seem to find the part i need.
27 Jan 2016 18:22 #42280 by FDR
27 Jan 2016 19:44 #42282 by Dante1
FDR wrote: ehirobo has it in stock:
www.ehirobo.com/spare-parts/transmitters...-upgrade-module.html
Yup, ordered it from there.
Do you know if I have to remove the old module and install the new one?
27 Jan 2016 19:58 #42284 by FDR
Replied by FDR on topic Dev 7e Module mod gone bad
Yes, you at least need to disconnect the old one, which is the same...
28 Jan 2016 12:38 #42312 by Dante1
FDR wrote: Yes, you at least need to disconnect the old one, which is the same...
Thanks. Hope it will bring my TX back to life. :)
31 Jan 2016 16:29 #42465 by FDR
I don't have a diagram, but the module installation guides for the Devo8 and 7e do contain assigned pins:
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleInstallation
08 Mar 2016 15:18 #44266 by lahiru4216
Replied by lahiru4216 on topic Dev 7e Module mod gone bad
Here is the link for your module replacing
www.hacksmods.com/2014/10/wk-devo-s-mod-module-for-devo7e/
<<<<<<<<Fly Harder For More Fun>>>>>>>
Time to create page: 0.695 seconds
