Devo 10 having a Glich
25 Jan 2016 15:52 #42204 by jbewley
Devo 10 having a Glich was created by jbewley
It would appear that My Devo 10 has a virus or something, as it is acting strangely. Sticks are in Mode 2 but react as if in Mode 1 and now it will not let me reload Deviation.
Is there a processor or hard drive, so to speak, tha can be replaced in the Devo 10 tx???
26 Jan 2016 07:33 #42228 by mwm
Replied by mwm on topic Devo 10 having a Glich
When you mount it as a USB drive, you can format the drive. The mode 1/mode 2 issues sounds like a bug we believe is fixed, but the inability to reload deviation is a new one. Well, maybe. Exactly what is going wrong when you try and install deviation?
26 Jan 2016 15:24 #42240 by jbewley
Replied by jbewley on topic Devo 10 having a Glich
mwm wrote: When you mount it as a USB drive, you can format the drive. The mode 1/mode 2 issues sounds like a bug we believe is fixed, but the inability to reload deviation is a new one. Well, maybe. Exactly what is going wrong when you try and install deviation?
I load the firmware via the DfUs tool. Next i open under USB, format the drive, copy and drag the files into the drive.
When I turn the TX on, the main screen (helicopter and trim bars are not there. It just says "Model1". I press ent and all the other screens are there.
I go to Tx config. Scroll down to "main page config". Hit "load" and I get "H:O Y:O".
26 Jan 2016 16:45 #42244 by linux-user
Replied by linux-user on topic Devo 10 having a Glich
Hi jbewley.
Is this the first time you are installing deviation on a Devo transmitter?
If so:
I would suggest you start again from scratch (including downloading deviation )
How to upgrade Devo TX to Deviation Firmware
Which DFUse tool do you use?
You can get it from there: walkera-fans.de/downloads/
26 Jan 2016 16:49 #42245 by jbewley
linux-user wrote: Hi jbewley.
If so:
Thank you. I will start from scratch, try it again and report back..
26 Jan 2016 18:43 #42251 by jbewley
Ok, Deviation loaded correctly this time. I did not use one of the "nightly builds" so the file is simply "Devo10-v4.0.1", with no letters afterwards.
Only problem is the file does not include the "KN" protocol I need for my FX070C heli. It was also missing the "hardware" file. I added it separately.
Is there a file for the DN protocol, ir should I try another version??
26 Jan 2016 22:34 #42258 by mwm
4.0.1 doesn't use a hardware.ini file, and will ignore the addition.
If 4.0.1 doesn't include the KN protocol, you'll needed to install the nightly to get it. You may also needed to change the wording on any additional modules you have installed to get the best performance.
26 Jan 2016 22:35 #42259 by jbewley
All is good again. I honestly can not tell you what I did, but after several tries, the program took, the KN protocol was there and I got my moodle loaded. B)
Thanks for the guidance guys.
Jim
Time to create page: 0.410 seconds
