Poor Reception with NRF Module and Devo10
08 Feb 2016 01:05 #42750 by Edrjune1
Okay, so I have tried and tried to get the reception on my NRF module to do anything. I'm getting about 10 feet, but it's working will as long as I am within that range. I have searched the forum and found this but it doesn't help a lot since I have already done all that. Has anyone else had this issue. I am using the NRF24L01 with the Uf.l connector and an exterior antenna. The range at 150mw is about 10 feet, but any less wattage and it's pretty much nonexistant. I'd love anything new to try, but even direction to start would be great. Thanks guys.
08 Feb 2016 03:04 #42753 by Jasenk
Replied by Jasenk on topic Poor Reception with NRF Module and Devo10
Do you have PA+LNA option on your nrf24l01 module?
Is it enabled in the TX.ini?
has_pa-nrf24l01=1 (uncomment this)
In model menu, model setup, is Tx power set to 100-150 mW?
-Jasen
08 Feb 2016 03:47 - 08 Feb 2016 03:50 #42754 by Edrjune1
Replied by Edrjune1 on topic Poor Reception with NRF Module and Devo10
I assume it is. It is this one. I have the TX set to 150 only because no other power setting will go over a foot or so. It is enabled as far as I know in harware.ini both lines have the colon taken out. It binds to my CX-Model CX023 and my Protocol Video Drone xt (a Attop YD829 clone) just fine. My only issue is the range.
Last edit: 08 Feb 2016 03:50 by Edrjune1.
Time to create page: 0.201 seconds
