Model.ini files on different devos
09 Feb 2016 15:09 #42843 by julianholzner
Model.ini files on different devos was created by julianholzner
Does anybody know if i can use my model.ini files from my devo 12s transmitter also on a devo 10??
I mean just copy them to the devo 10 without making any further thing?!
Thanks for your help
09 Feb 2016 16:26 - 09 Feb 2016 16:27 #42848 by jamichx
Replied by jamichx on topic Model.ini files on different devos
julianholzner wrote: Does anybody know if i can use my model.ini files from my devo 12s transmitter also on a devo 10??
I do not know that but just copy it over and see what happens. Copy it to a free slot and this way you cant do any harm.
Last edit: 09 Feb 2016 16:27 by jamichx.
09 Feb 2016 19:41 - 09 Feb 2016 19:42 #42867 by mwm
Replied by mwm on topic Model.ini files on different devos
It'll depend on what you use. The 12 has more switches than the 10, and some of the 3-way switches on the 12 are 2-way switches on the 10. The 12 also has more analog inputs than the 10. If your model file uses any of those, you'll have things you could do on the 12 that you can't do on the 10.
Last edit: 09 Feb 2016 19:42 by mwm.
09 Feb 2016 20:49 #42870 by julianholzner
Replied by julianholzner on topic Model.ini files on different devos
Thanks for the info,
So i think everything will work as i use only the fmd, mix and trhld switch.
Tomorrow i will tewt everything and let you know!
10 Feb 2016 05:03 #42909 by mwm
FMODE and MIX are 3-way switches on the 10, so no problem. But the 10 doesn't have a throttle hold switch, so you'll have to fix that. There are recent posts that describe different ways to fix switches as well as having links to the wiki page listing switches on the non-FPV transmitters.
Time to create page: 0.109 seconds
