QUADS are moving all to the right side
09 Feb 2016 21:43 #42878 by Artus
I use DEVO 10 and a nightly since today the newest - thanks for the great job -
all my QUADS - Hubsan Q4 - Walkera QRW100S - Ladybird V1 move to the right side
but not with the original radios
Andybody an idea what is going wrong?
My Hubsan Q4 shuts off the LEDs after binding - since I use the nightly but I dont know how to switch on this small bird is hard to find without light ;)
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
09 Feb 2016 22:11 #42882 by camousse
Replied by camousse on topic QUADS are moving all to the right side
Is your radio calibration correct ?
09 Feb 2016 22:22 #42885 by Artus
Replied by Artus on topic QUADS are moving all to the right side
I think so - i have calibrated new - and my TREX 100 is flying "normal" (like the orignal radio)
09 Feb 2016 22:34 #42887 by camousse
May be the trim is not at neutral position. But it is strange it is the same behaviour for all the quads (except if you copy the models)
If trim is at neutral, you can use them to fix problem (make some click to the left ;-)
09 Feb 2016 22:38 #42888 by RedSleds
Replied by RedSleds on topic QUADS are moving all to the right side
Calibrate the sticks AND both aux pots.
10 Feb 2016 04:21 - 10 Feb 2016 04:22 #42907 by vlad_vy
Replied by vlad_vy on topic QUADS are moving all to the right side
For Hubsan, CH5 manage leds.
Walkera quads (6 axis) compensate any trims in time of auto bind. You need zero all trims, place quad on level surface, auto bind, test flight, if exist any drift place peace of paper under leg(s) from the direction of drift, auto bind, test flight ... at the end if you get level flight, assign Fixed ID.
Last edit: 10 Feb 2016 04:22 by vlad_vy.
11 Feb 2016 03:13 #42977 by Artus
Thanks a.lot for all your advices.
I don't copy the models
I calibrate the sticks and the potis
I made several tests and I decide to use a workaround. I change the servo mid of the roll channel of every quad I have to use between 5,5 und 7,5
Time to create page: 0.132 seconds
