QUADS are moving all to the right side
- Artus
09 Feb 2016 21:43 #42878
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
QUADS are moving all to the right side was created by Artus
I use DEVO 10 and a nightly since today the newest - thanks for the great job -
all my QUADS - Hubsan Q4 - Walkera QRW100S - Ladybird V1 move to the right side
but not with the original radios
Andybody an idea what is going wrong?
My Hubsan Q4 shuts off the LEDs after binding - since I use the nightly but I dont know how to switch on this small bird is hard to find without light
- camousse
09 Feb 2016 22:11 #42882
by camousse
Replied by camousse on topic QUADS are moving all to the right side
Is your radio calibration correct ?
- Artus
09 Feb 2016 22:22 #42885
by Artus
Replied by Artus on topic QUADS are moving all to the right side
I think so - i have calibrated new - and my TREX 100 is flying "normal" (like the orignal radio)
- camousse
09 Feb 2016 22:34 #42887
by camousse
May be the trim is not at neutral position. But it is strange it is the same behaviour for all the quads (except if you copy the models)
If trim is at neutral, you can use them to fix problem (make some click to the left
- RedSleds
09 Feb 2016 22:38 #42888
by RedSleds
Replied by RedSleds on topic QUADS are moving all to the right side
Calibrate the sticks AND both aux pots.
10 Feb 2016 04:21 - 10 Feb 2016 04:22 #42907
Replied by vlad_vy on topic QUADS are moving all to the right side
For Hubsan, CH5 manage leds.
Walkera quads (6 axis) compensate any trims in time of auto bind. You need zero all trims, place quad on level surface, auto bind, test flight, if exist any drift place peace of paper under leg(s) from the direction of drift, auto bind, test flight ... at the end if you get level flight, assign Fixed ID.
Last edit: 10 Feb 2016 04:22 by vlad_vy.
- Artus
11 Feb 2016 03:13 #42977
by Artus
Thanks a.lot for all your advices.
I don't copy the models
I calibrate the sticks and the potis
I made several tests and I decide to use a workaround. I change the servo mid of the roll channel of every quad I have to use between 5,5 und 7,5
Time to create page: 0.030 seconds
- QUADS are moving all to the right side
