Connecting TX to PC running Emulator ?
10 Feb 2016 16:54 #42956 by mzbeg
I am running 7e emulator on my PC using keyboard. I find it very combersome. Is it possible to connect my TX with this emulator on my PC. Or is it possible to connect Micrsoft Joystick to it. I have searched every where but only found info for connecting TX to Sim. Thanks for your help.
12 Feb 2016 13:54 #43036 by mario123
Replied by mario123 on topic Connecting TX to PC running Emulator ?
Hallo,
why are you doing this? What do you try to achieve?
Mario
12 Feb 2016 14:14 #43038 by mzbeg
Replied by mzbeg on topic Connecting TX to PC running Emulator ?
I simply wants to know the purpose of this emulator. Please bear in mind I am new to all this. I programe model.ini on my TX for a particular model and on channel monitor I can see the result then on my model itself I can fine tune the model.ini. People are using this emulator, but how they use it, I have not found a clue anywhere, except how to install and run and its keys. I think some body should make a video as how to use it after seting up the emulator.
12 Feb 2016 14:20 #43039 by mario123
I have just used it for setting up a model but I'm rather doing this on my remote. Another usage is if you want to test deviation and haven't got a devo. I don't know more reasons to use it.
12 Feb 2016 14:26 #43040 by mzbeg
Would you please explain what remote you are using. Thanks
12 Feb 2016 15:00 #43042 by mario123
I'm using a devo 10.
12 Feb 2016 16:19 #43043 by mzbeg
So do I. I have 7e. I do all my setting on it. This is why I am asking what is the use of emulator.
12 Feb 2016 23:40 - 12 Feb 2016 23:41 #43064 by jamichx
Replied by jamichx on topic Connecting TX to PC running Emulator ?
mzbeg wrote: So do I. I have 7e. I do all my setting on it. This is why I am asking what is the use of emulator.
To use PC instead of TX. You can program model on you PC then transfer it to your TX. Its called emulator because it emulates your TX in your case 7e. Sometime the programming may take long time. Working on PC can be faster and save your TX battery.
Last edit: 12 Feb 2016 23:41 by jamichx.
Time to create page: 0.579 seconds
