Connecting TX to PC running Emulator ?
- mzbeg
10 Feb 2016 16:54 #42956
by mzbeg
Connecting TX to PC running Emulator ? was created by mzbeg
I am running 7e emulator on my PC using keyboard. I find it very combersome. Is it possible to connect my TX with this emulator on my PC. Or is it possible to connect Micrsoft Joystick to it. I have searched every where but only found info for connecting TX to Sim. Thanks for your help.
- mario123
12 Feb 2016 13:54 #43036
by mario123
Replied by mario123 on topic Connecting TX to PC running Emulator ?
Hallo,
why are you doing this? What do you try to achieve?
Mario
Mario
- mzbeg
12 Feb 2016 14:14 #43038
by mzbeg
Replied by mzbeg on topic Connecting TX to PC running Emulator ?
I simply wants to know the purpose of this emulator. Please bear in mind I am new to all this. I programe model.ini on my TX for a particular model and on channel monitor I can see the result then on my model itself I can fine tune the model.ini. People are using this emulator, but how they use it, I have not found a clue anywhere, except how to install and run and its keys. I think some body should make a video as how to use it after seting up the emulator.
- mario123
12 Feb 2016 14:20 #43039
by mario123
I have just used it for setting up a model but I'm rather doing this on my remote. Another usage is if you want to test deviation and haven't got a devo. I don't know more reasons to use it.
- mzbeg
12 Feb 2016 14:26 #43040
by mzbeg
Would you please explain what remote you are using. Thanks
- mario123
12 Feb 2016 15:00 #43042
by mario123
I'm using a devo 10.
- mzbeg
12 Feb 2016 16:19 #43043
by mzbeg
So do I. I have 7e. I do all my setting on it. This is why I am asking what is the use of emulator.
- jamichx
12 Feb 2016 23:40 - 12 Feb 2016 23:41 #43064
by jamichx
To use PC instead of TX. You can program model on you PC then transfer it to your TX. Its called emulator because it emulates your TX in your case 7e. Sometime the programming may take long time. Working on PC can be faster and save your TX battery.
Replied by jamichx on topic Connecting TX to PC running Emulator ?
mzbeg wrote: So do I. I have 7e. I do all my setting on it. This is why I am asking what is the use of emulator.
Last edit: 12 Feb 2016 23:41 by jamichx.
Time to create page: 0.492 seconds
- Connecting TX to PC running Emulator ?
