Nightly Builds Update Devo 7e
18 Feb 2016 22:54 #43262 by jamichx
Nightly Builds Update Devo 7e was created by jamichx
Two questions:
1. Do I need (is it better) to upgrade to newest version if all working fine with the version I have currently installed ?
2. If I want to upgrade how do I proceed ? (what exactly delete what to keep )
Thank you
19 Feb 2016 01:04 #43270 by Thomas.Heiss
Replied by Thomas.Heiss on topic Nightly Builds Update Devo 7e
What version are you running.
What protocol.
What features are you looking forward.
19 Feb 2016 14:42 #43312 by jamichx
Replied by jamichx on topic Nightly Builds Update Devo 7e
Thomas.Heiss wrote: What version are you running.
What protocol.
v4.0.1-583c468
dsmx, devo, slysky
all is working just fine not looking forward anything just asked generally if update needed as I can see there are new updates released and if updating how exactly do that no to loose any of my settings.
thanks
20 Feb 2016 17:44 #43371 by cyclops13
Replied by cyclops13 on topic Nightly Builds Update Devo 7e
Wow! You asked the same question I was going to ask!
Even I have the same version installed and see that there are so many new versions available now.
What are we missing? I saw the release notes are only for 4.01, not for nightly builds..
20 Feb 2016 20:05 - 20 Feb 2016 20:07 #43374 by jamichx
cyclops13 wrote: Wow! You asked the same question I was going to ask!
Not sure if we miss anything. Cant see any note about updates. So I guess if its all working ok we juts leave it and do not upgrade ?
Also if upgrade how to do that ? Its obvious how to install it but cant find any notes, manual how to safely upgrade from one version to another.
Last edit: 20 Feb 2016 20:07 by jamichx.
20 Feb 2016 20:14 #43375 by FDR
Replied by FDR on topic Nightly Builds Update Devo 7e
No, actually there is a manual, which describes how to upgrade.
Please read it...
20 Feb 2016 22:08 #43384 by Richard96816
Replied by Richard96816 on topic Nightly Builds Update Devo 7e
jamichx wrote: Two questions:
Thank you
Good questions. It would be nice to reorganize this web site or add a status page to be able to answer those kinds of questions with a couple clicks. Maybe tables of protocols and transmitters, etc., with comments or links to most recent developments regarding each one. Manually maintained, or something simple and automatic or semi-automatic. Semi-automatic would be a check-box added to posting to say this item is worthy of recognition on or near the homepage. Perhaps allowing others to vote on it's importance, to deal with things that may not be as important.
The value of these sorts of tools should not be underestimated. Saving people's time and keeping them well informed is what this site is all about. It's what keeps people coming back.
21 Feb 2016 06:34 #43398 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Nightly Builds Update Devo 7e
In the manuals under "upgrade notes" it doesn't actually say how to do the update, just says to backup your models. Basically you use upgrade with dfuse, without the formatting of the USB, then copy across all folders. Note that even though there's plenty of space I usually get a message saying there isn't enough space, so I just delete everything and copy in the new folders, and the backup copy of my models and modelico directories (and select files from the media in my case due to custom skins)
21 Feb 2016 08:47 #43401 by mwm
Replied by mwm on topic Nightly Builds Update Devo 7e
I always read "Upgrade Notes" as things that you wanted to do differently from the installation procedure described in the previous section.
I can see how the title of the previous section might cause you to skip it, which could easily lead to not reading it that way. Suggestions for an introductory sentence for that section appreciated, as I don't like what I've come up with.
21 Feb 2016 13:52 - 21 Feb 2016 13:54 #43406 by jamichx
FDR wrote: No, actually there is a manual, which describes how to upgrade.
Please read it...
I do not want to be pain but it looks like I am not on my own who can not find this detailed nightly builds upgrade manual you are talking about. Can I ask you kindly to point me and the others to it please ?
Last edit: 21 Feb 2016 13:54 by jamichx.
21 Feb 2016 14:33 #43410 by Sero
Replied by Sero on topic Nightly Builds Update Devo 7e
It's in the manual, for sure...
2.2. Upgrade notes
If you are upgrading from a previous Deviation release, it is strongly recommended that you back-up the ‘models’ directory from the transmitter as well as the tx.ini file to ensure you don’t lose any model or transmitter configuration. Copy all directories except for the ‘models’ directory and the tx.ini file to the transmitter. Optionally, copy the ‘models’ directory to the transmitter except for the currently configured model files. This last step will ensure that the defaults for newly created models have the latest options set. If the tx.ini file is overwritten, the stick calibration must be repeated and any settings reset.
21 Feb 2016 15:44 - 21 Feb 2016 15:46 #43418 by jamichx
Sero wrote: It's in the manual, for sure...
2.2. Upgrade notes
thank you but this is manual for deviation release not the nightly builds. Nowhere in there nightly builds are mentioned. There is no hardware.ini in original deviation firmware neither. maybe this should be updated or extra manual for nightly could be released.
Last edit: 21 Feb 2016 15:46 by jamichx.
21 Feb 2016 16:33 #43419 by FDR
There will be no user manual for each nightly build, because as you probably know, nightly builds are the result of an automatic build system, and are built every time there is a change in the code.
The documentation tries to cover all aspects of this firmware whether it is an "official" release or a nightly build.
There might not be any official releases anyway, so get used to the nightlies...
21 Feb 2016 19:11 #43426 by Deal57
Replied by Deal57 on topic Nightly Builds Update Devo 7e
I've attached my suggested additions for the online User Manuals. The material addresses the Nightly and Test builds in suggested new sections 2.4 and 2.5. While I pulled much of the text from a variety of posts, it's possible I've erred or overstated something, so please make changes as needed.
It seems to me that the Nightly builds for the 7e do NOT require you to copy the protocols folder, is this correct? If it isn't, then we need to add it to the section for the Nightly. I don't think it's needed for the Test builds simply because, well, if you know how to use them, you know what to do (or am I overthinking this?).
File Attachment:
File Name: Nightlyand...ilds.txt
File Size:3 KB
21 Feb 2016 19:25 #43427 by FDR
No, the protocol files are only valid with the firmware they were compiled with, so you need to overwrite them every time you upgrade the fw...
21 Feb 2016 20:18 #43429 by Deal57
Yes, that's actually what I meant :blush: . With the nightly you copy over everything, with the test builds you may only get a protocols folder to copy over, right? But I didn't want to bring up that level of detail in the User Manual's Test Builds section.
21 Feb 2016 20:24 - 21 Feb 2016 20:31 #43430 by Sero
I checked in the latest nightly, and it seems to be the full monty, including a hardware.ini...
Last edit: 21 Feb 2016 20:31 by Sero.
21 Feb 2016 21:33 #43431 by mwm
Test builds are developer specific, and you should follow the instructions from the developer who created them.
But running the protocols folder and dfu built from different sources will almost never work. So if a test build only has a protocols folder, the developer expected you've already got the right dfu to install
21 Feb 2016 21:38 - 21 Feb 2016 22:02 #43432 by jamichx
FDR wrote: There will be no user manual for each nightly build, because as you probably know, nightly builds are the result of an automatic build system, and are built every time there is a change in the code.
well this statement does not help me to understand how exactly proceed when updating nightly builds does it ? So again back to my question how exactly do I upgrade from older version of nightlies to new one on devo 7e ? I need explanation of that procedure exactly how to do it. What to install new what to copy what to keep from old version so after I finished I end up with working hardware and all may settings intact. I hope I made my self clear this time. It would be very good if someone made this kind of general procedure manual.
And there is still the other question I asked unanswered. Do I need to upgrade is it essential even my old version is working ? Thanks to who ever will be able to answer.
Here is the example of possible answer> if you look at the Sero's picture above with all the files and folders. I need someone to say first you need to use dfu file to update the firmware then you copy these and these files over but make sure you keep these and these old files and folders. Something like that for devo 7e
it also says here www.deviationtx.com/forum/5-news-announc.../1416-nightly-builds that the Devo7e uses the devo10 filesystem which confused me also so when I go here www.deviationtx.com/downloads-new/catego...s-nightly-2016-02-09 I see files for 7e and for devo 10. Now am I supposed to use devo 10 zip file or what ? This is really confusing.
who ever wrote this www.deviationtx.com/forum/5-news-announc.../1416-nightly-builds wrote it from position of someone who know exactly what to do like notes for him/her self not for other users.
Last edit: 21 Feb 2016 22:02 by jamichx.
21 Feb 2016 21:41 - 21 Feb 2016 21:47 #43433 by mwm
+Deal57, you submit changes to the manual the same easy you submit bug reports and feature requests - via the Bug Tracker (poor name - it's really a general issue tracker) in the menu.
I like the idea of adding a build type discussion to the manual. Any chance you could submit a pull request for these changes? But maybe hold of a day or so - I'm hoping to reorganize the installation section to deal with upgrades vs. new installations in a better manner. And the new deviation installer to it.
You do need to mention that the hardware connections for some extra modules changed after 4.0.1, so they should review the wiki page on extra modulrs if updating from 4.0.1.
Last edit: 21 Feb 2016 21:47 by mwm. Reason: Add suggestion to review hardware connections.
Time to create page: 0.689 seconds
