Has anyone got Deviation to work w/ DRL Simulator?
05 Mar 2016 03:46 #44128 by mellowvision
I downloaded DRL Simulator and it recognizes the Devo using USBHID... upon initial load, it had the sticks swapped, so that right stick was throttle and yaw. Left stick was doing nothing. I managed to switch the inputs using the Devo menus, and now throttle and yaw are on the left, but the right stick is doing nothing.
Can someone walk me through how they got theirs to work? I am using a Devo 6s.
05 Mar 2016 20:28 #44161 by AppMeow
I was just thinking the same thing. Anyone get it working?
05 Mar 2016 21:41 #44163 by TomPeer
I just give it a try. It works with follow settings:
channel 1: rudder - reverse
channel 2: throttle - normal
channel 3: none
channel 4: aileron - reverse
channel 5: elevator - reverse
File Attachment:
File Name: model5.ini
File Size:4 KB
09 Mar 2016 06:58 - 09 Mar 2016 06:58 #44308 by mellowvision
Replied by mellowvision on topic Has anyone got Deviation to work w/ DRL Simulator?
thanks for the upload and tips... I tried both manually entering the set up as listed and installing the ini file. neither worked. If anyone else has a devo 6s and can give this a shot, it would be great to figure out how to get this up and running.
just to be clear - the throttle and rudder work, but the other controls are disabled.
Last edit: 09 Mar 2016 06:58 by mellowvision.
14 Mar 2016 20:18 #44573 by AppMeow
Got it working thanks a bunch!
22 Mar 2016 00:34 #44954 by kahuna001
Same here. Only the left stick works.
21 Dec 2016 16:39 #57102 by mattyj
I just got my Devo7E with Deviation to work on the latest DRL using TomPeers ini. file above. Had to reverse elev.
Can't wait to really put it to the test!!
28 Dec 2016 09:43 #57284 by eddyjp
I've got a Devo 10 with a 3-in-1 included. I got it to work with the Freerider sim by plugging an audio cable into the QSC port on the back and using SmartPropoPlus on my Windows machine, but, I can't seem to get the Devo 10 to work with the DRL sim.
Can you explain the steps you went through? I tried using the model5.ini from TomPeers, but I think there are a few steps that I need to follow before loading that. Any help would be greatly appreciated.
28 Dec 2016 14:07 #57292 by mattyj
A friend of mine had to create his own ini. file, the one for the Devo 7E didn't work on his Devo 10. I used my usb plug to connect to PC.
With the right model selected on my TX, I started DRL and checked other when selecting remote. Just followed directions from that point.
I will see if he can share his ini. file he created.
28 Dec 2016 14:23 #57294 by eddyjp
That would be great. Yes, please see if you can get the ini file.
28 Dec 2016 16:39 - 28 Dec 2016 16:40 #57301 by eddyjp
Just to let everyone know, I figured out how to get DRL working with a Devo 10 on a Win 7 machine
1) plug in a USB into the back and connect this
2) create a completely new model in the Devo 10
3) set the protocol to USBHID
4) in the Windows game controller settings, make sure Deviation GamePad appears
5) click on properties and choose the settings menu.
6) calibrate the controller following the instructions. Click skip or next if one of the options is not working (e.g. no controller movements changes anything)
7) click apply and ok
8 ) go to DVL and click on the controller settings
9) select "other" as the controller
10 ) follow the instructions and set the controller settings there. Remember to wait for "next" to appear before trying to set the controls. Don't worry if some are reversed as you can invert them at the end of the settings wizard.
I hope that helps!
Last edit: 28 Dec 2016 16:40 by eddyjp.
11 Mar 2017 02:43 #60109 by Darksnow
Can you tell me the process in detail? I'm having some trouble getting any input from the transmitter to the pc. I have a Dell Inspiron 7000 running Windows 10 and it has a single jack for audio and mic. Also I already installed the latest deviation firmware.
04 Jul 2017 05:33 #63279 by gikan76
I recomend to set up during the DRL calibration the Raw input check, otherwise the throttle has got a 10% dead zone at default.
14 Jul 2017 22:10 - 14 Jul 2017 22:10 #63447 by Newman
Just downloaded DRL SIM for Mac and hoping to give it a try with Deviated Devo 7E :)
Last edit: 14 Jul 2017 22:10 by Newman.
Time to create page: 0.892 seconds
