cant select multi in model menu deviation v4.0.1?
07 Mar 2016 03:15 #44207 by matacks
hello, I have just installed modules in a devo 7e and am testing it out with a few models.
i had success binding to a hisky hcp80. it seems a few channels need to be switched but its working.
the problem Ive run into is when trying to bind to a hubsan H111 pico quad. Im trying to select multi as model type but the only options that deviation are showing are plane and heli.. is the multi option missing from this version? Im still able to bind in either with either heli or plane selected but the model doesn't work correctly. Three out of four rotors spin up making it uncontrollable.
Im still very much a deviation newb at this point.. and mostly hoping I just did a good enough job with the soldering and nothing is botched there. haha
thanks for any feedback.
07 Mar 2016 04:07 #44208 by RedSleds
Use the latest Nightly Build.
The v4.0.1 release does not have a lot of protocols and features that the Nightly Builds do have.
Time to create page: 0.392 seconds
