DEVO7e Virtual switches R+ and L-
- Maco33
09 Mar 2016 09:04 #44314
by Maco33
DEVO7e Virtual switches R+ and L- was created by Maco33
DEVO7e
It is possible to use physical buttons L- and R+ for virtual channels?
Thanks.
Thanks.
09 Mar 2016 14:56 #44329
Replied by mwm on topic DEVO7e Virtual switches R+ and L-
Yes. It's called a "virtual switch", and it's documented in the last chapter of the manual linked to in the left hand menu.
- Maco33
09 Mar 2016 17:50 - 09 Mar 2016 19:47 #44335
by Maco33
Replied by Maco33 on topic DEVO7e Virtual switches R+ and L-
I do not understand, physical buttons EXT, UP+ and DN- me as virtual switches operate normally. But the R + L and I do not work. It is possible to adjust somehow.
Last edit: 09 Mar 2016 19:47 by Maco33.
- Cereal_Killer
12 Mar 2016 17:55 #44472
by Cereal_Killer
Replied by Cereal_Killer on topic DEVO7e Virtual switches R+ and L-
To use trim buttons for virtual channels you'll have to setup both the virtual channel and the trim sections of the devo. First you'll have to setup the trim buttons themselves how you want them to behave (momentary / on-off and which ones) then setup the virtual channel.
- ColdBrew
12 Mar 2016 23:32 #44489
by ColdBrew
Replied by ColdBrew on topic DEVO7e Virtual switches R+ and L-
hi Cereal_Killer, can you help me answering this question for me please? thank you.Cereal_Killer wrote: To use trim buttons for virtual channels you'll have to setup both the virtual channel and the trim sections of the devo. First you'll have to setup the trim buttons themselves how you want them to behave (momentary / on-off and which ones) then setup the virtual channel.
- DEVO7e Virtual switches R+ and L-
