x4r-sb not bindin devo 7e
- Alexandro
13 Mar 2016 19:20 #44516
by Alexandro
Replied by Alexandro on topic x4r-sb not bindin devo 7e
the Wire job is not to bad. 7 to 9 is the Pa enable, may be here a little error ( pad looks a bit burned with solder iron)
i can report mid of the week, i have bought a X4r sb for me to Test on the 8s. May be i solder a cc2500 into my 7e to verify the Build with it.
i report then
greetings Alex
i report then
greetings Alex
- Alexandro
16 Mar 2016 15:48 #44652
by Alexandro
Hello, X4R SB with newest non EU does Bind with my 8S and Telemetry works with out any Problem.
On Weekend a new 7e is coming ( i do not want to rip my 7e with 3 Modules apart, so i ordert a new one
I report then with the new TX on Weekend or next Week.
greetings Alex
greetings Alex
- Nitro_123
16 Mar 2016 20:47 #44670
by Nitro_123
Replied by Nitro_123 on topic x4r-sb not bindin devo 7e
Thanks Alex. I appreciate it.
I'll ask the seller if he may have shipped it with eu firmware.
I'm going to have to find someone with a taranis and bind it to theirs haha. Only thing i can think of right now
- Alexandro
17 Mar 2016 16:10 #44722
by Alexandro
i have my New 7e ready with the cc2500 and the latest FrskyX Test Build Ver. d76
The Bind and Servos are working with the X4rSB ( Last non EU updated by me with the Sport to USB Update Tool)
my last Tip for You, do You have the Channel Number set to 12 bevor Bind ?
if the green LED does Blink fast after Bind then it is ready connected and Channel 3 is Throttle ( to test with Servo )
i hope it helps
greetings Alex
i hope it helps
greetings Alex
- Arakon
18 Mar 2016 17:49 #44792
by Arakon
Replied by Arakon on topic x4r-sb not bindin devo 7e
I just bound with absolutely no issue to an X4R-SB non-EU. Either you have a bad receiver, or it's not non-EU.
- Nitro_123
19 Mar 2016 00:18 #44813
by Nitro_123
Thanks for all the updates guys. Will ask the seller whether the receiver is non-eu. Will also try and find other frsky stuff to bind to.
I have a feeling that the cc2500 is dead/bad. What do you guys think ?
- Alexandro
19 Mar 2016 12:56 #44827
by Alexandro
some one had a similar Problem with his CC2500, but it was the other one ( at the list of the wire Info Page ).
The Module was working normal but after some Time it was going bad.
Do you have a other RX or flyer who need the CC2500 ? then you can test the TX Module ( the only difference is the Software Protocol )
I have 2 of the blue CC2500 , 2 X 7105 and all are ok.
May be yours is damaged , changing it is the cheapest way. The next is the USB Dongle from Frsky with updating the Firmware.
If your seller is outside EU then the RX should a non EU Version.
If You need more Info for buying the right Dongle, Firmware Version, Handling for Updating then ask, i try to help !
greetings Alex
greetings Alex
- Nitro_123
24 Mar 2016 02:10 - 24 Mar 2016 06:03 #45068
by Nitro_123
Thanks for helping everyone.
My x4r just died today
It doesn't turn on anymore.
I think it might have been a problem with it from day 1
I'm going to get a replacement and report back
Edit: I forgot to mention that it did NOT bind to a taranis plus.
Last edit: 24 Mar 2016 06:03 by Nitro_123. Reason: more info
- philongct
16 Aug 2016 10:11 - 16 Aug 2016 10:12 #52803
by philongct
Replied by philongct on topic x4r-sb not bindin devo 7e
It could be a bad module. I experienced the same.
As X series need a very precise crystal to perform manual calibration so I suspected that's the bad module.
Can you try a D8? It use automatic calibration and may work
Last edit: 16 Aug 2016 10:12 by philongct.
Time to create page: 0.089 seconds
- x4r-sb not bindin devo 7e
