Devo F12E 20dB
- Blisk
11 Mar 2016 19:00 #44439
by Blisk
Devo F12E 20dB was created by Blisk
I have Devo F12E with firmware 1.6B
That means it is locked on 10mW.
I have tried to upload firmware 1.6A but after uploading it says wrong firmware.
Is it possible to unlock 20dB power on devo F12E or there is a differend hardware in it so it is not possible?
11 Mar 2016 19:49 #44442
Replied by FDR on topic Devo F12E 20dB
Usually they have the same hardware, it is only a software limitation in the bootloader.
If you install deviation, you can use it at full power...
- Blisk
11 Mar 2016 22:07 - 12 Mar 2016 08:10 #44444
by Blisk
Replied by Blisk on topic Devo F12E 20dB
I see in settings that, there is 20dB but can't select it
which one to install? for devo F12E?
Why original firmware doesn't work?
Last edit: 12 Mar 2016 08:10 by Blisk.
- Thomas.Heiss
12 Mar 2016 08:45 #44456
by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo F12E 20dB
Where do you live? Europe?
Probably your TX is locked down where you bought it from?
- Blisk
12 Mar 2016 09:15 #44457
by Blisk
I know it is locked because I bought it in Germany.
Question is how can I unlock it. Is it hardware or just software.
Yesterday I have opened two TX one TX5811 and one TX5810.
And as I see difference is only in one shortage. I did 't tested yet but I will.
I hope F12E is only software locked
- Thomas.Heiss
12 Mar 2016 18:15 - 12 Mar 2016 18:17 #44474
by Thomas.Heiss
So where are you now located? Still DE/EU?
Makes IMHO no sense at all to fly
DEVO (3 channel DSSS) as a non true FHSS >10mw
with new ETSI 1.8.1 starting 01.01.2015 in Europe
Would be better to switch to DSmx (>=15CH FHSS) @ 100mW.
Well there is none confirmation of conformity for that class @100mW from Walkera/DE-distributor, right? So probably that makes no sense too...but still a little bit better than DSM2 or DEVO DSSS protocols
My 2cents
Thomas
My 2cents
Thomas
Last edit: 12 Mar 2016 18:17 by Thomas.Heiss.
- Blisk
12 Mar 2016 18:51 #44476
by Blisk
no I am in Slowenien!
"Would be better to switch to DSmx (>=15CH FHSS) @ 100mW.
Sorry but really don't know what you are telling me.
- Thomas.Heiss
12 Mar 2016 19:26 #44477
by Thomas.Heiss
You shall switch in Europe from DEVO to Spektrum DSMx protocol if you are going to install DeviationTX firmware.
Especially if you want to fly with >10mW output power (like DSMx@100mW).
12 Mar 2016 20:32 #44479
You always look at this from the regulations pont of view, and forget that.from the technical point of view the DEVO protocol is a rock solid rc system with longer effective range then DSMX.
I don't think that it has more risk in Europe, then in other countries, where it is legal...
- Blisk
12 Mar 2016 22:47 - 12 Mar 2016 22:50 #44485
by Blisk
Thomas.Heiss
sorry don't understand what you are saying.
Still need to learn more about it.
Last edit: 12 Mar 2016 22:50 by Blisk.
- Blisk
12 Mar 2016 22:50 #44486
by Blisk
regulations in my country about that are still not in law.
And if there will be soon, that is in few years, I can still use it in neighbour country where that regulations wont be in law for nex 20 years.
I thought to change my devo E12F with someone in Germany where regulations are strict and have enabled 20dB, my E12F is new out of the box
- Thomas.Heiss
13 Mar 2016 13:27 #44504
by Thomas.Heiss
Interesting! Thanks for letting me know that FDR.
Then it would make sense to fly the Walkera F210 quad (3+2mm bottom frame plates) quad just on the DEVO protocol for better range
Thomas
FDR wrote: You always look at this from the regulations pont of view, and forget that.from the technical point of view the DEVO protocol is a rock solid rc system with longer effective range then DSMX.
Thomas
Time to create page: 0.682 seconds
- Devo F12E 20dB
