Devo F12E 20dB
11 Mar 2016 19:00 #44439 by Blisk
Devo F12E 20dB was created by Blisk
I have Devo F12E with firmware 1.6B
That means it is locked on 10mW.
I have tried to upload firmware 1.6A but after uploading it says wrong firmware.
Is it possible to unlock 20dB power on devo F12E or there is a differend hardware in it so it is not possible?
11 Mar 2016 19:49 #44442 by FDR
Replied by FDR on topic Devo F12E 20dB
Usually they have the same hardware, it is only a software limitation in the bootloader.
If you install deviation, you can use it at full power...
11 Mar 2016 22:07 - 12 Mar 2016 08:10 #44444 by Blisk
Replied by Blisk on topic Devo F12E 20dB
I see in settings that, there is 20dB but can't select it
which one to install? for devo F12E?
Why original firmware doesn't work?
Last edit: 12 Mar 2016 08:10 by Blisk.
12 Mar 2016 08:45 #44456 by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo F12E 20dB
Where do you live? Europe?
Probably your TX is locked down where you bought it from?
12 Mar 2016 09:15 #44457 by Blisk
I know it is locked because I bought it in Germany.
Question is how can I unlock it. Is it hardware or just software.
Yesterday I have opened two TX one TX5811 and one TX5810.
And as I see difference is only in one shortage. I did 't tested yet but I will.
I hope F12E is only software locked
12 Mar 2016 18:15 - 12 Mar 2016 18:17 #44474 by Thomas.Heiss
So where are you now located? Still DE/EU?
Makes IMHO no sense at all to fly
DEVO (3 channel DSSS) as a non true FHSS >10mw
with new ETSI 1.8.1 starting 01.01.2015 in Europe
Would be better to switch to DSmx (>=15CH FHSS) @ 100mW.
Well there is none confirmation of conformity for that class @100mW from Walkera/DE-distributor, right? So probably that makes no sense too...but still a little bit better than DSM2 or DEVO DSSS protocols :-)
My 2cents
Thomas
Last edit: 12 Mar 2016 18:17 by Thomas.Heiss.
12 Mar 2016 18:51 #44476 by Blisk
no I am in Slowenien!
"Would be better to switch to DSmx (>=15CH FHSS) @ 100mW.
Sorry but really don't know what you are telling me.
12 Mar 2016 19:26 #44477 by Thomas.Heiss
You shall switch in Europe from DEVO to Spektrum DSMx protocol if you are going to install DeviationTX firmware.
Especially if you want to fly with >10mW output power (like DSMx@100mW).
12 Mar 2016 20:32 #44479 by FDR
You always look at this from the regulations pont of view, and forget that.from the technical point of view the DEVO protocol is a rock solid rc system with longer effective range then DSMX.
I don't think that it has more risk in Europe, then in other countries, where it is legal...
12 Mar 2016 22:47 - 12 Mar 2016 22:50 #44485 by Blisk
Thomas.Heiss
sorry don't understand what you are saying.
Still need to learn more about it.
Last edit: 12 Mar 2016 22:50 by Blisk.
12 Mar 2016 22:50 #44486 by Blisk
regulations in my country about that are still not in law.
And if there will be soon, that is in few years, I can still use it in neighbour country where that regulations wont be in law for nex 20 years.
I thought to change my devo E12F with someone in Germany where regulations are strict and have enabled 20dB, my E12F is new out of the box
13 Mar 2016 13:27 #44504 by Thomas.Heiss
FDR wrote: You always look at this from the regulations pont of view, and forget that.from the technical point of view the DEVO protocol is a rock solid rc system with longer effective range then DSMX.
Interesting! Thanks for letting me know that FDR.
Then it would make sense to fly the Walkera F210 quad (3+2mm bottom frame plates) quad just on the DEVO protocol for better range :-)
Thomas
Time to create page: 0.194 seconds
