What is your devo 7e dsmx range test results?
20 Mar 2016 12:15 - 31 Mar 2016 02:49 #44863 by lahiru4216
i have upgraded devo 7e module with walkera smod module.i had turn on devo 7e without antena so many times.i think i have fried smod module.but t works with 300m range at 150mw.i did a range test at 100uf with storm s603 6ch rx. the range was 3m.
I want to know what is your range to know my module is working or not ?
Note:i can get 20m with devo pritocol at 100uf output power!! :huh:
<<<<<<<<Fly Harder For More Fun>>>>>>>
Last edit: 31 Mar 2016 02:49 by lahiru4216. Reason: update range using devo protocol
20 Mar 2016 17:47 #44878 by djdazzy
Replied by djdazzy on topic What is your devo 7e dsmx range test results?
I can get 40m in 100uW mode.
21 Mar 2016 09:25 - 21 Mar 2016 09:31 #44910 by lahiru4216
Replied by lahiru4216 on topic What is your devo 7e dsmx range test results?
Using S-mod upgraded module Devo 7e ?
Last edit: 21 Mar 2016 09:31 by lahiru4216.
22 Mar 2016 15:22 #44984 by ursus69
Replied by ursus69 on topic What is your devo 7e dsmx range test results?
My Devo7E with the S-mod upgrade, have 3m of range in dsmx/devo 100uW...
It's faulty?
23 Mar 2016 00:34 #45014 by lahiru4216
djdazzy said that he can get 40m in 100uW mode.
28 Mar 2016 11:18 #45331 by ursus69
Anyone can help us?? Any solution? Idea?
I recently changed my stock module by the smod module, and have 3-5 meters in 100uW (devo protocol)....it's faulty?
thanks!!
28 Mar 2016 18:44 #45348 by Thomas.Heiss
Replied by Thomas.Heiss on topic What is your devo 7e dsmx range test results?
On Spektrum AR600 (antenna diversity, no parallel antenna Fades B/L as no vertical satellite) I do NOT get up to 40m (LOS, holds)! It stops (LOS) at ~33-34/max 35m for me.
Here are my DSMx ground tests - probably will move result numbers to "DSM telemetry support range" or a new thread
- repeating AR6210 + AR8000 +1mw range tests
- nightly-build firmware updates on DSM protocol changes (vlad changed DSM code in nightly build after fcd0669)
- Indigos DSM protocol test build (big DSM code changes)
Devo10 on nightly build 4.0.1-fcd0669
LOS = complete loss of signal (rudder test) = >0 holds
300µw = ca. more +12-13m distance compared to 100µw
Spektrum AR600 + TM1000:
100µw ~33-34m/max 35m with no LOS / 0 holds (at that big distance for 100µw there are many (>40) FrameLosses and a view telemetry out of range
300µw ~45-47m/max 48m with no LOS / 0 holds (at that big distance for 300µw there were very many (>40) FrameLosses)
1mw (=Spektrum range test ~30-35m) to be re-tested: I had up to ~60-65m with no LOS / 0 holds / not that many FrameLosses on AR600/AR6210/AR8000 last year.
Thomas
28 Mar 2016 22:19 #45358 by ursus69
Thanks Thomas!
Anyone know what would be the problem? Bad Smod module?
Another failed component?
Thanks again
30 Mar 2016 05:16 #45419 by lahiru4216
"ursus69"
Did you turned on your devo 7e tx without antena ?
30 Mar 2016 07:06 #45421 by lahiru4216
ursus69 wrote: Anyone can help us?? Any solution? Idea?
thanks!!
Dont be afraid.I also get 2m with using dsmx reciever and s mod moudle at 100uw.but i can get 20m with devo rx1002 using smod module at 100uf.from now i have to replace rx of all my rc models to devo rx to get better range.
30 Mar 2016 07:15 #45422 by ursus69
thanks!!
You get 20m at 100uW with Devo?
I tried with a QrLadybird (Devo),... and I only get 5 meters at 100uW..
I think that I don't turned on tx without antena...but once maybe..
30 Mar 2016 08:09 #45426 by Thomas.Heiss
BTW: What build version are you running? Latest nightly build? With or without telemetry turned on?
Yes, it's sometimes kinda hard to track all nightly build repository code changes, but there have been changes on DSM and DEVO generally spoken.
And I know from testing Indigos DSM test build versions that there can be (were) differences of FrameLosses or distance (e.g in his versions) in how the protocols and telemetry RX<->TX modes are implemented.
This is the latest DSM protocol nightly-build commit by vlad_vy:
4b3dc91 DEVO and DSM protocol updates 2015-07-29
You should either use at least this nightly build version 4b3dc91 (or newer/latest) or at least the nightly-build I successfully use: fcd0669
30 Mar 2016 08:13 #45427 by Thomas.Heiss
30 Mar 2016 10:04 #45430 by Fernandez
Replied by Fernandez on topic What is your devo 7e dsmx range test results?
I have made a simple rf field strength meter, basically dc meter rf diode and resistor.
i have mentioned this in the past but there is a huge amount of difference in emmitted power depending on protocols.
Using Frsky, setting to lowest power 100uW, the field strength measured is as strong as dsm (x) field strength at Full power level.
Frsky at full 150mW my meter goes out of scale, while with DSM only 15% of Scale.
Then ther Devo protocol has bit more power than spectrum, while using same RF chip..
I am not so sure if range check 100uW rangecheck is always fair. Doing range check with FRsky you have to walk huge distances, it keeps working., it is much furghter than original Frsky module. When range check with Frsky original Tx, my meter does not measure any rf, so must ver very low indeed.
Flysky protocol with A7105, also has lots of emitted energy second powerfull i saw, but bit less than FRsky.
30 Mar 2016 11:32 #45432 by djdazzy
lahiru4216 wrote: djdazzy said that he can get 40m in 100uW mode.
I can confirm I get between 30 - 40 m in range check mode using a standard tx module in a Devo 7e and one of these orange receivers.
www.hobbyking.com/hobbyking/store/__3209...S_BUS_2_4Ghz_Rx.html
I used a recent nightly build or FrksyX test build.
30 Mar 2016 14:48 #45438 by ursus69
Thanks for the reply Thomas, Fernandez & djdazzy
Thomas.Heiss wrote: BTW: What build version are you running? Latest nightly build? With or without telemetry turned on?
Im running nightly Devo7e- V4.0.1-dfa9397 (January 2016)... Without telemetry
It could be the problem?
Is there no way to know if the module is fried? with a multimeter or similar?....or only testing with range tests?
31 Mar 2016 02:45 - 31 Mar 2016 02:46 #45479 by lahiru4216
Thanks Thomas.Heiss , Fernandez , djdazzy .for the quick reply.
Last edit: 31 Mar 2016 02:46 by lahiru4216.
31 Mar 2016 03:27 #45481 by lahiru4216
I will report you the range using devo 10 using latest nightly builds.
01 Apr 2016 04:41 #45535 by lahiru4216
15m with devo 7e and devo 10 using cheap rx.i think spektrum one usually beat 40 at 1mw.
01 Apr 2016 15:41 - 01 Apr 2016 15:41 #45578 by lahiru4216
here is 12s RF module
Last edit: 01 Apr 2016 15:41 by lahiru4216.
Time to create page: 0.296 seconds
