Binding issue?
- Death_From_Above
28 Mar 2016 01:40 - 28 Mar 2016 01:40 #45316
by Death_From_Above
Binding issue? was created by Death_From_Above
hi all, new here.
i just installed devo7e-v4.0.1-f5d851e and uploaded fine. it will bind to my super cp, solopro 228 and cb100. but with a few issues.
super cp- for some reason the servos don't move as smoothly. also entered in my settings i was flying with into the new firmware and now i have no lift and acts funny. gyro acts all crazy.
cb100 and solopro- both bind but also have jittery servo movements. no matter if i switch the swash type around or revers servos, they dont move appropriately or in the right direction.
should i reinstall deviation-emu_devo7e-v4.0.1-f5d851e and try again? or go back to stock firmware.? or did i overlook something???
Last edit: 28 Mar 2016 01:40 by Death_From_Above. Reason: .
- RedSleds
28 Mar 2016 01:51 - 28 Mar 2016 01:52 #45320
by RedSleds
Replied by RedSleds on topic Binding issue?
Ummm, ......the deviation-emu_devo7e is an emulator that runs on a PC.
Last edit: 28 Mar 2016 01:52 by RedSleds.
- Death_From_Above
28 Mar 2016 03:36 #45323
by Death_From_Above
my bad, copy n paste mistake . i installed this version -devo7e-v4.0.1-f5d851e.
i reinstaled my original walkera firm ware to confirm my CP is flying fine.
and using my original wk2403 on the cb100 was perfect
so should i try the original deviation 4.0.1?
Replied by Death_From_Above on topic Binding issue?
RedSleds wrote: Ummm, ......the deviation-emu_devo7e is an emulator that runs on a PC.
- victzh
28 Mar 2016 06:27 #45325
by victzh
Replied by victzh on topic Binding issue?
Calibrate your sticks, it's not binding issue, it's sticks.
- Death_From_Above
28 Mar 2016 13:30 #45332
by Death_From_Above
thanks, ill try that again. tonight after work ill try installing the older 4.0.1 to see if it makes a differnece.
victzh wrote: Calibrate your sticks, it's not binding issue, it's sticks.
- Death_From_Above
28 Mar 2016 15:20 #45341
by Death_From_Above
victzh-
wait, are you saying calibrate the sticks for each model?
maybe thats what i missed.
- Arakon
28 Mar 2016 15:21 #45342
by Arakon
Replied by Arakon on topic Binding issue?
Stick calibration is stored globally, so it's only needed once.
- victzh
28 Mar 2016 15:58 #45343
by victzh
Yea, as Arakon said - once after installing Deviation on your Devo. Also you battery should have enough charge so that the Deviation would be able to save these settings.
- Death_From_Above
29 Mar 2016 17:15 #45389
by Death_From_Above
i reinstalled deviation and everthings working much better. thanks all for the input.
Time to create page: 0.597 seconds
- Binding issue?
