Devo 7e 100uf 2m with dsmx & 20m with Devo rx
30 Mar 2016 07:17 #45423 by lahiru4216
I did a range test today using two rxs.
Transmitter: Devo 7E with 12s module
Devo protocol:Devo rx1002
Dsmx protocol:Storm s603 rx
I decreased tx output to 100uf with firmware.put transmitter on the 1ft from the ground and walk with rx. both rx have dual antenas.
Devo rx: 20m without blinking led :woohoo:
Storm s603 dsmx : 2m without blinking led(not sure how can get using spektrum full range rx) :S
I don't know the reason for range huge difference.test using same tx.same environment.i think it is better to have devo rxs instead of dsmx rx.
<<<<<<<<Fly Harder For More Fun>>>>>>>
30 Mar 2016 07:59 #45425 by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 7e 100uf 2m with dsmx & 20m with Devo rx
Just a suggestion because of 3 active threads:
1) Throw away your Storm RX and try with a new (from HH dealer) genuine Spektrum DSMx AR600, AR610 or better AR6210, AR8000 + TM1000
2) If you can not get at least 30-35m@1mw and 0-40F (<40) Spektrum FlightLog FrameLosses: Buy a new full 8s/10/12s HF module and try that (which you have not toasted / turned on without a properly connected antenna)
www.deviationtx.com/forum/6-general-disc...e-test-results#45348
31 Mar 2016 03:12 #45480 by lahiru4216
Replied by lahiru4216 on topic Devo 7e 100uf 2m with dsmx & 20m with Devo rx
I can't figure out 12s module fried or not ? i will check the range using devo 10 and report back to forum.
31 Mar 2016 17:28 #45506 by Thomas.Heiss
You really need to test different Spektrum DSMx receiver too!
01 Apr 2016 04:27 #45532 by lahiru4216
I think dsmx range failure is a rx problem.it's a cheap rx.i think better range with spektrum one.
01 Apr 2016 04:39 #45534 by lahiru4216
I got the 15m range with devo 7e and devo 10 with cheap rx.i get the same range.i cant figure out 12s module fried or not ?
01 Apr 2016 12:46 - 01 Apr 2016 12:49 #45560 by aMax
Well, if Devo works for you,the module is not fried. You better check the rx, since I am able to get the same range with a S603 as you posted for the RX1002. The weakness is the antenna part. Signal aplification by a simple RF transistor (AAG) and no diversity..
If the antennas are well oriented, it outperforms the RX615X (no LNA but diversity),.....but unfortunately not at flying a quad etc."
Edit: check this part of the rx (photo...
Last edit: 01 Apr 2016 12:49 by aMax.
01 Apr 2016 15:25 #45573 by lahiru4216
Thanks "aMax" you gave me hopeful answer !
01 Apr 2016 15:30 - 01 Apr 2016 15:37 #45575 by lahiru4216
Picture of 12S RF
Last edit: 01 Apr 2016 15:37 by lahiru4216.
Time to create page: 0.281 seconds
