Devo 7 Switch Change! ?
- datamedic
30 Mar 2016 21:24 - 30 Mar 2016 21:24 #45467
by datamedic
Devo 7 Switch Change! ? was created by datamedic
Hello guys , im using devo 7 for 3 years now and never had a problem and very happy with it
however recently i changed my fbl unit with one that has a "rescue" function
since now every time i was going to crash i was using as expected the thrlhold switch
the problem is that im used to hit that switch evry time something isnt going fine and i want "if posible" to asign to thrhold switch the GEAR switch which activating the rescue
any idea how i can do that?
thank you in advance
Last edit: 30 Mar 2016 21:24 by datamedic.
- RoGuE_StreaK
30 Mar 2016 22:59 #45472
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo 7 Switch Change! ?
Devo 7 or Devo 7E?
Devo 7 isn't supported by Deviation, and AFAIK functionality can't be changed.
- datamedic
30 Mar 2016 23:24 #45473
by datamedic
Replied by datamedic on topic Devo 7 Switch Change! ?
devo 7...
well i guess ill hardware change the switches then :/
thank you for the fast reply
- datamedic
31 Mar 2016 18:09 #45507
by datamedic
hello again
actually is posible
you just have to assign the gyro to hold switch
for anyone that might be having the same problem
actually is posible
Time to create page: 0.520 seconds
- Devo 7 Switch Change! ?
