Please Help!! Why arent channels Aux4 and Aux5 wor
- maxxteezy
20 Apr 2016 08:22 #46850
by maxxteezy
Please Help!! Why arent channels Aux4 and Aux5 wor was created by maxxteezy
I have a Devo 10 and the Stock 10 Channel Rx with 4.01 and I cant figure out why Aux4 and Aux5 wont come on. I use the Advanced Mixer setting and those 2 channels just have the thick looking block in the middle. I have my ESC connect to Aux 5 and a Servo to Aux 4 and neither one will activate. Where can i find a diagram to see which channels are what? It worked fine with the stock firmware now I cant get all of my functions anymore. Please help. I don't know where to find out what switch is what anywhere.
- sbstnp
20 Apr 2016 08:51 #46851
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Please Help!! Why arent channels Aux4 and Aux5 wor
How do you have them configured? On which channels?
AuxX at transmitter and auxY at receiver can be different. When in doubt, count the channels at the RX side: 1,2,3,4,5 (GEAR), 6(AUX1), 7(AUX2) and so on. Then in your mixer, assign for example for channel 6 source as AUX4, then your left pot will control this channel.
Good luck
Good luck
Devo 10 + 4in1
20 Apr 2016 08:52 #46852
Replied by FDR on topic Please Help!! Why arent channels Aux4 and Aux5 wor
...also make sure you've calibrated the pots too in the stick calibration process.
- RoGuE_StreaK
20 Apr 2016 08:54 #46853
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Please Help!! Why arent channels Aux4 and Aux5 wor
Not quite sure what you mean by "thick looking block in the middle"; check out sections 8.2 and 8.3 in the manual for examples of what the AUX should look like.
Best place to check physical inputs is in the Input Monitor, not entirely sure where that is hidden on a 10/7E, might be under config/settings/something like that?
- Thomas.Heiss
21 Apr 2016 05:18 #46915
by Thomas.Heiss
Replied by Thomas.Heiss on topic Please Help!! Why arent channels Aux4 and Aux5 wor
Its for the Devo10 in the transmitter config / channel monitor.
You just have to use the (top) right button(s) to scroll from page1 channels to page2 inputs.
Time to create page: 0.518 seconds
- Please Help!! Why arent channels Aux4 and Aux5 wor
