TRIM_LV+ and - as PID adjustment switches [SOLVED]
23 Apr 2016 14:37 - 23 Apr 2016 19:22 #47050 by mickkn
Do anyone know how the set the mixers so that: TRIM_LV+ is +100 on a channel and TRIM_LV- is -100 on the same channel, and 0 when not pressed.
I'm on DEVO10
Right now I have the AUX4 POT as the PID selecter in Cleanflight, and instead of using the AUX5 POT as the adjust channel, I would like the Thrust trim instead. But can't seem to get it just right.
EDIT (SOLVED):
Trim settings:
Input: Virt2
Trim Step: Momentary
Trim +: TRIMLV+
Input: Virt3
Trim +: TRIMLV-
Mixer:
Virt2
Complex
Mixers: 1
Switch: Optional to enable/disable tuning. I choose AILEDR1
Mux: Replace
Source: Virt2
Curve: 1-to-1
Scale: 0
Trim
Virt3
Complex
Mixers: 1
Mux: Replace
Source: Virt3
Curve: 1-to-1
Scale: 0
Trim
Ch12
Mixers: 2
Page1
Switch: None
Mux: Replace
Src: Virt3
Curve: Zero/Max
Scale: -100
Offset: 0
No trim
Page2
Switch: None
Mux: add
Src: Virt2
Curve: Zero/Max
Scale: 100
Offset: 0
No trim
Last edit: 23 Apr 2016 19:22 by mickkn.
Time to create page: 0.590 seconds
