NRF24L01 problem Help!!
27 Apr 2016 17:28 #47319 by EvilDasher
NRF24L01 problem Help!! was created by EvilDasher
I have installed the module and took extra care to make sure all connections were properly soldered and nothing was touching, however in my excitement to test it I forgot to attach the antenna :( I powered it for about 30 Seco do before realizing it and quickly turned off the controller and plugged in the antenna. When I turn on the controller now it says the module is missing and I fear I have blown it. Did I, am I know looking at getting a new one?
27 Apr 2016 17:39 #47320 by RedSleds
Replied by RedSleds on topic NRF24L01 problem Help!!
Post your hardware.ini file that is currently on your Tx.
27 Apr 2016 19:11 #47323 by EvilDasher
Replied by EvilDasher on topic NRF24L01 problem Help!!
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 0
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
enable-nrf24l01 = A13
; has_pa-nrf24l01 = 1
; enable-multimod = A13
28 Apr 2016 00:06 #47338 by RedSleds
What firmware are you running?
High rez pictures of your wiring and soldering job would also be helpful.
For the hardware.ini:
Add a ; in front of the CYRF line.
If your nRF transceiver has +PA +LNA, remove semicolon from the has_pa-nrf24l01 = 1 line
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
; has_pa-cyrf6936 = 0
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
Time to create page: 0.275 seconds
