Difference between DFU mode and USB mode?
- mickkn
29 Apr 2016 19:02 #47439
by mickkn
Difference between DFU mode and USB mode? was created by mickkn
Having a hard time getting my Devo 10 in USB mode.
I have tried a lot now. But my Devo10 will not show up as a Storage Device on any of my 3 computers
Tried 5 different USB cables (all being able to flash via DFU)
Tried with different stock firmware versions before flashing Deviation (DFU flashing no problem)
Are there any difference from DFU and USB mode, datawise?
The USB mode sometimes show up on my PC and I actually had succes formatting it to FAT 4096KB a couple of times, but when tranfering files it suddenly stops and will never get a connection again.
Sometimes it just says something about USB device not recognized
any hints ?
any hints ?
29 Apr 2016 19:59 #47441
Replied by PhracturedBlue on topic Difference between DFU mode and USB mode?
DFU mode and USB mode are completely different. Is DFU mode reliable on all of your machines?It seems odd that you can program in DFU mode and yet not be able to transfer files in USB mode. If you could do neither, than I'd think it may be a loose connection on the board, but if DFU works and USB does not, I'm not sure what to make of it.
- mickkn
29 Apr 2016 20:14 #47446
by mickkn
Replied by mickkn on topic Difference between DFU mode and USB mode?
I got absolutely no problem flashing the DFU files, stock(+ LIB file) and deviation. But USB mode is very unstable. Faulty STM32 chip?
- mickkn
29 Apr 2016 20:21 - 29 Apr 2016 20:21 #47448
by mickkn
Is this screen normal?
A bit worried about the picture quality or is it just a Contrast thing?
https://www.dropbox.com/s/dy9a49ju1p3uj9a/USB_Mode.jpg?dl=0
Last edit: 29 Apr 2016 20:21 by mickkn.
- Arnold
29 Apr 2016 21:29 - 30 Apr 2016 20:30 #47456
by Arnold
Replied by Arnold on topic Difference between DFU mode and USB mode?
On my Devo 10, which works perfectly, it looks like this.
<link removed by owner>
Last edit: 30 Apr 2016 20:30 by Arnold.
30 Apr 2016 03:50 #47470
mickkn, there is nothing wrong with your screen. It is possible that the core frequency is off a little causing USB errors. it is hard for me to guess. I wouldn't even know how to attempt to debug that. There is, however, another option for you. The deviationUploader java utility can upload the filesystem to your Tx directly from DFU mode. it is much slower, but it should bypass the usb mount issue I think.
- mickkn
30 Apr 2016 04:51 #47472
by mickkn
That would solve the problem partly
- mickkn
30 Apr 2016 04:52 - 30 Apr 2016 07:43 #47473
by mickkn
Is there a guide somewhere?
EDIT: Think the deviation uploader tool fixed my issue. The USB is working for now
the tool only worked from my Mac though. Maybe something with java on my win machines. Thanks
Last edit: 30 Apr 2016 07:43 by mickkn.
30 Apr 2016 14:10 #47488
Replied by mwm on topic Difference between DFU mode and USB mode?
Note that you still need it, but if someone else is looking for a guide to the deviation uploader, the online manuals (links on the left) installation chapter partially cover using the dfu uploader. They're targetted at the F series controllers, which require it, but the same instructions should largely apply.
Time to create page: 0.294 seconds
- Difference between DFU mode and USB mode?
