Invert switch
- Iroquois
03 May 2016 12:55 #47654
by Iroquois
Invert switch was created by Iroquois
Those of us who have been flying model helis for a long time, used to fly inverted by means of an 'Invert switch'. Is there any way that this can be done on a Devo 7e? You need to reverse elevator, rudder and pitch. The pitch is fairly easy, but what about the others?
03 May 2016 13:17 #47660
Replied by PhracturedBlue on topic Invert switch
I'm not sure why you say the pitch is easy to setup but the ele/rud are not.
You should be able to use either of the following methods:
1) setup an expo-DR channel with a chosen swithc and set the scale to -100
2) setup a 2 page complex mixer using the switch to negate the input channel.
- Iroquois
03 May 2016 14:44 #47666
by Iroquois
Replied by Iroquois on topic Invert switch
I knew there must be at least one way to do it, but my 80 year old brain doesn't work as well as it did. Many thanks.
- aMax
03 May 2016 14:56 #47669
by aMax
Replied by aMax on topic Invert switch
Do you mean the Skyartec WASP AUTO CP " one key Switchover" ?
It is done by the flight controller. You need to know on which channel this is switched and then program it on the 7e.
- tcaudill01
03 May 2016 20:21 - 03 May 2016 20:22 #47696
by tcaudill01
If you figure this out, can you please share your results? I would be very interested in seeing how this is accomplished.
Replied by tcaudill01 on topic Invert switch
Iroquois wrote: I knew there must be at least one way to do it, but my 80 year old brain doesn't work as well as it did. Many thanks.
Last edit: 03 May 2016 20:22 by tcaudill01.
- Iroquois
04 May 2016 12:21 #47727
by Iroquois
I haven't flown it yet but this should do the trick.
SW B0 = normal flight,
SW B1 = 3d (full throttle with symmetrical pitch curve),
SW B2 = Inverted pitch curve with reversed elevator and rudder.
Hold works as normal and the other switches can be used to change rates, etc.
- Iroquois
04 May 2016 12:23 #47728
by Iroquois
Sorry aMax, I don't know that system.
Time to create page: 0.144 seconds
- Invert switch
