Invert switch
03 May 2016 12:55 #47654 by Iroquois
Invert switch was created by Iroquois
Those of us who have been flying model helis for a long time, used to fly inverted by means of an 'Invert switch'. Is there any way that this can be done on a Devo 7e? You need to reverse elevator, rudder and pitch. The pitch is fairly easy, but what about the others?
03 May 2016 13:17 #47660 by PhracturedBlue
Replied by PhracturedBlue on topic Invert switch
I'm not sure why you say the pitch is easy to setup but the ele/rud are not.
You should be able to use either of the following methods:
1) setup an expo-DR channel with a chosen swithc and set the scale to -100
2) setup a 2 page complex mixer using the switch to negate the input channel.
03 May 2016 14:44 #47666 by Iroquois
Replied by Iroquois on topic Invert switch
I knew there must be at least one way to do it, but my 80 year old brain doesn't work as well as it did. Many thanks.
03 May 2016 14:56 #47669 by aMax
Replied by aMax on topic Invert switch
Do you mean the Skyartec WASP AUTO CP " one key Switchover" ?
It is done by the flight controller. You need to know on which channel this is switched and then program it on the 7e.
03 May 2016 20:21 - 03 May 2016 20:22 #47696 by tcaudill01
Replied by tcaudill01 on topic Invert switch
Iroquois wrote: I knew there must be at least one way to do it, but my 80 year old brain doesn't work as well as it did. Many thanks.
If you figure this out, can you please share your results? I would be very interested in seeing how this is accomplished.
Last edit: 03 May 2016 20:22 by tcaudill01.
04 May 2016 12:21 #47727 by Iroquois
I haven't flown it yet but this should do the trick.
SW B0 = normal flight,
SW B1 = 3d (full throttle with symmetrical pitch curve),
SW B2 = Inverted pitch curve with reversed elevator and rudder.
Hold works as normal and the other switches can be used to change rates, etc.
04 May 2016 12:23 #47728 by Iroquois
Sorry aMax, I don't know that system.
Time to create page: 0.112 seconds
