Buttons as switches in Deviation files.
- vmsda
04 May 2016 16:51 #47750
by vmsda
Buttons as switches in Deviation files. was created by vmsda
In the "Mired in RC" tutorial on Deviation, ir is said that
"Button switches
Any of the buttons on the transmitter, including those used for navigating the transmitter configuration, can be used as a virtual switch. This requires setting them up as trims for a virtual channel, and then using the virtual channel as a switch".
How are these buttons labelled, in order to be referenced in the mixers?
"Button switches
- silpstream
04 May 2016 18:29 #47759
by silpstream
Replied by silpstream on topic Buttons as switches in Deviation files.
Try here:
www.deviationtx.com/manuals/html-devo10/...-as-a-virtual-switch
You have to assign them to the virtual channels first.
- vmsda
05 May 2016 10:04 #47811
by vmsda
Replied by vmsda on topic Buttons as switches in Deviation files.
Yes, ok for the trims, but how do you accomplsh that for "... buttons ... used for navigating the transmitter configuration ..."?silpstream wrote: Try here: www.deviationtx.com/manuals/html-devo10/...-as-a-virtual-switch
- silpstream
05 May 2016 11:16 #47812
by silpstream
05 May 2016 14:05 #47820
That's the introductory tutorial. If you go the "writing a deviationTx model" tutorial, the last section covers the various uses of buttons as inputs (toggle switches, momentary switches, even a replacement for an analog input) in detail.
Replied by mwm on topic Buttons as switches in Deviation files.
vmsda wrote: In the "Mired in RC" tutorial on Deviation, ir is said that
"Button switches
- Fernandez
05 May 2016 14:58 #47824
by Fernandez
Replied by Fernandez on topic Buttons as switches in Deviation files.
Slightly off topic; switches and sticks could be just moved and get detected entered in the setup fields, for trims I opened a bug at the time, as when moving a trim switch it is not detected, must be manually scrolled.
Time to create page: 0.195 seconds
- Buttons as switches in Deviation files.
