Devo 10 and Win7
- LITE
11 May 2016 21:32 #48232
by LITE
Devo 10 and Win7 was created by LITE
Welcome!
I have Devo 10 now:)
Firmware upgrade to 4.0.1, but Windows 7 need to format memory.
Is that ok? What now?
Best Regards
LITE
Best Regards
LITE
- Flightless Bird
11 May 2016 22:44 - 11 May 2016 22:49 #48235
by Flightless Bird
Hello!
I am also a DEVO-10 user. Great piece of gear! Consider buying a spare while you still can, apparently that model is no longer made.
First off, 5.0.0 is released, it's better and supports more protocols. Consider it.
Second, yes... format is part of the process. Format MUST be done as FAT, with 4096 byte sectors. I tried other formats (including FAT32), and they do NOT work.
Finally, you probably know this already... but after format, you need to copy all the firmware files EXCEPT for two (the main firmware .dfu file and the debug .ZIP file) to the newly formatted drive.
Post if you have any other questions... I recently set my Devo-10 up, and it's all still fresh in my mind.
Replied by Flightless Bird on topic Devo 10 and Win7
LITE wrote: Welcome!
Best Regards
LITE
Hello!
Last edit: 11 May 2016 22:49 by Flightless Bird.
- LITE
12 May 2016 15:02 #48279
by LITE
Replied by LITE on topic Devo 10 and Win7
Something strange.
In V5 software I haven't *.dfu file.
On display I have 4.0.1 version.
- HappyHarry
12 May 2016 16:58 #48284
by HappyHarry
Replied by HappyHarry on topic Devo 10 and Win7
download this file here >>
www.deviationtx.com/downloads-new/catego...mu-devo10-v5-0-0-zip
and follow the instructions for installation in the manual here >>
www.deviationtx.com/user-manual/user-manual-7e-10
that should get you working properly
- LITE
12 May 2016 21:38 #48300
by LITE
Formatted memory, installed step-by-step as in the manual and still 4.0.1 version
File from link don't contains dfu file. Version 4 has it.
What is deviation-emu?
- HappyHarry
12 May 2016 21:47 #48301
by HappyHarry
sorry my mistake i linked you to the emulator, here is the proper link, and there is a dfu inside this zip file >>
www.deviationtx.com/downloads-new/catego...on-devo10-v5-0-0-zip
- LITE
13 May 2016 20:39 #48374
by LITE
Welcome!
I've downloaded file, installed and have a new problem
AUX4 is missing. How to recover original software?
Recovered with version 0.8A, but screen is illegible.
How to reset all settings on V5 version?
13 May 2016 22:59 #48391
Replied by mwm on topic Devo 10 and Win7
To go back to the original firmware, you have to install both the dfu and the library, Not installing the library tends to result in a scrambled screen. I don't recall how to install the library, though.
What do you mean by "AUX4 is missing"?
- LITE
14 May 2016 08:41 #48401
by LITE
On original software all knobs and sticks works ok.
After deviation installation AUX4(potentiometer) is not working.
14 May 2016 08:56 #48402
Replied by FDR on topic Devo 10 and Win7
It won't work until you confihured it for some channel. Furthermore you need to calibrate it too with the stick calibration process...
- LITE
14 May 2016 10:47 - 14 May 2016 10:50 #48408
by LITE
OK, I will try it, but now, in "Channel monitor" aux4 don't works.
How to reset model settings or full reset of software?
In original software was function "reset" in a few kinds...
Last edit: 14 May 2016 10:50 by LITE.
- Deal57
14 May 2016 12:30 #48419
by Deal57
Replied by Deal57 on topic Devo 10 and Win7
Do you see it in "input monitor"? Go to channel monitor and press the R+ button. If it is visible there then you just need to configure a channel to use it. If it is not there, that could be an issue.
- LITE
14 May 2016 13:43 #48426
by LITE
Ok, it works.
Thanks for Your help:)
Time to create page: 1.003 seconds
- Devo 10 and Win7
