Deviation and USB dongle
15 May 2016 10:39 #48481 by LITE
Deviation and USB dongle was created by LITE
Hello!
Is possible to configure Deviation 5 with USB dongle for PC simulator like PhoenixRC or RealFlight?
Best Regards
LITE
15 May 2016 11:16 #48482 by TheSFReader
Replied by TheSFReader on topic Deviation and USB dongle
I don't know if it's compatible with these flight simulators, but I use smartpropoplus ( www.smartpropoplus.com/site/ ) to connect my 7e to my computer : it translates PPM signals (from the "trainer cable" ) to emulate a windows joystick.
15 May 2016 11:36 #48484 by Arakon
Replied by Arakon on topic Deviation and USB dongle
TheSFReader wrote: I don't know if it's compatible with these flight simulators, but I use smartpropoplus ( www.smartpropoplus.com/site/ ) to connect my 7e to my computer : it translates PPM signals (from the "trainer cable" ) to emulate a windows joystick.
Why? Deviation supports full USB joystick functionality natively.
15 May 2016 12:43 #48487 by TheSFReader
You're right, but I prefer the "audio" cable /connection, the USB one gets in the way when I hold the tx
15 May 2016 13:43 #48490 by Cereal_Killer
Replied by Cereal_Killer on topic Deviation and USB dongle
TheSFReader wrote: You're right, but I prefer the "audio" cable /connection, the USB one gets in the way when I hold the tx
I found that to so I went out and bought a 90° USB adapter. Problem solved.
15 May 2016 19:32 #48495 by HappyHarry
Replied by HappyHarry on topic Deviation and USB dongle
I personally know the 7e works with several sim usb dongles including xtr and realflight, and a friend says it works with the wireless type dongle plugged into a realflight dongle also
11 Jun 2016 13:49 #50399 by LITE
Replied by LITE on topic Deviation and USB dongle
Sorry for my absence. I still can't use devo 10 with newest Deviation software to USB dogle.
How to setup Tx as joystick?
12 Jun 2016 14:17 #50471 by Cereal_Killer
Here's another idea...
www.rcgroups.com/forums/showthread.php?t=2117239
Only mod to devo is installing an A7105 module.
12 Jun 2016 14:25 #50472 by HappyHarry
lite set the protocol to ppm and plug in your dongle to the tx and the computer
Time to create page: 0.809 seconds
