Broken usb
19 May 2016 04:28 #48678 by Bhinman
Broken usb was created by Bhinman
I have a devo 7e with a broken usb port. Already loaded deviation software before it broke off inside. Opened it up and it was literally rolling around inside. Do I have to buy a new tx to load more models or future releases? Any other way to load software other than usb port?
19 May 2016 05:27 #48681 by silpstream
Replied by silpstream on topic Broken usb
You are quite stuck without the usb port if you want to copy files or upgrade.
Models can still be created manually on the tx itself.
Are you able to solder the usb port back on?
19 May 2016 06:40 #48685 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Broken usb
silpstream wrote: Are you able to solder the usb port back on?
If you yourself can't, then maybe try looking for a local hackerspace or the like.
Also, the solder pads may be torn off, so to make it easier to solder you may be better off getting a cheap cable like this one , cutting it apart to expose the wires, and soldering the individual wires to more accessible points on the circuit board. Added benefit of giving you a more flexible port for using with simulators etc. without breaking it again when you get caught up in the excitement.
20 May 2016 02:01 #48771 by Deal57
Replied by Deal57 on topic Broken usb
This has happened before, here is a link to one time. A more recent thread has photos, but I can't seem to find that thread.
So it's fixable!
21 May 2016 02:54 #48917 by Bhinman
Replied by Bhinman on topic Broken usb
Thanks for the suggestions! I'm going to give it a try...
21 May 2016 13:04 #48949 by Deal57
Found the missing link... Well, a link to someone who solved this... Here
02 Jun 2016 01:55 #49803 by 6Axis
Replied by 6Axis on topic Broken usb
Hello everyone!
I'm new on the site of the great flexsible Walkera Devo transmitter.
Thanks for all the useful information that I
have gotten here from all contributors!
On my Devo 10 I do not get installed
new software because the mini USB plug
have fallen completely off (cold soldering ? )
Can someone be kind and show me solder points on the main board for new WIRE and USB connector ?
Thank you in advance
With best regards
6Axis
Time to create page: 0.605 seconds
