Devo 7 (NOT 7e) upgrade help
- pherder
21 May 2016 02:30 #48914
by pherder
Devo 7 (NOT 7e) upgrade help was created by pherder
I am looking for the instructions to flash a Devo 7 with deviation firmware (i.e. the latest nightly build) but for the life of me, I cannot find where those instructions are!
I do have the UP02 adapter and have flashed my Devo 7 to the latest firmware located on the German site without much problem and have flashed my F12E, F7e, and 10 but all those have good instructions and are currently running.
Thanks in advance for any assistance!
Paul
Paul
- HappyHarry
21 May 2016 20:59 #48982
by HappyHarry
Replied by HappyHarry on topic Devo 7 (NOT 7e) upgrade help
the devo7 is not compatible with deviation firmware bud, the only 7ch deviation transmitters that work are the devo 7e and the devo f7
- Thomas.Heiss
22 May 2016 13:21 #49007
by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 7 (NOT 7e) upgrade help
Get a Devo 10.
- pherder
22 May 2016 13:32 - 22 May 2016 13:37 #49008
by pherder
Replied by pherder on topic Devo 7 (NOT 7e) upgrade help
D'oh! Thought I had a F7 (where there are nightlys available) but I see I have a "7".
So there are THREE "7"s ??? and I have two of them (yes, I have a 7e also with deviation on it but blew the diode mod so it doesn't transmit.)
Last edit: 22 May 2016 13:37 by pherder.
- pherder
22 May 2016 13:35 - 22 May 2016 13:39 #49009
by pherder
Have a 10 and a F12E both with deviation on them.
I guess I will use the Devo 601 RX I have and put it on one of my unused multirotors and sell this unloved "7".
Last edit: 22 May 2016 13:39 by pherder.
- Cereal_Killer
22 May 2016 15:13 #49020
by Cereal_Killer
Replied by Cereal_Killer on topic Devo 7 (NOT 7e) upgrade help
Sent you a PM sir...
- HappyHarry
22 May 2016 15:22 #49021
by HappyHarry
I have an already sucessfully range modded 7e cyrf module if you want to buy it to fix your 7e?
- pherder
22 May 2016 15:33 - 22 May 2016 16:56 #49023
by pherder
Thanks, HappyHarry but I have the 12S module to replace the internal module. Problem was I took off all the solder pads and now must try to solder to the pins that stick out.
I am in the process of moving (from the Wichita area to Dodge City and then from my rental to the house that I am having built) so a lot of my RC "stuff" is in storage... At least I HOPE it is in storage and that I can find it once I get moved into the house.
I just found my lighted magnifying glass and will attempt once again to try to solder to the pins left behind since now I MIGHT be able to see what I am doing.
WOOHOO!!! Having the right tools does make a difference! I found the wiring problem and corrected it and now my Devo7e works with deviation and I was able to bind my DSMX RX and do a range check.
HappyHarry wrote: I have an already sucessfully range modded 7e cyrf module if you want to buy it to fix your 7e?
Last edit: 22 May 2016 16:56 by pherder.
- HappyHarry
22 May 2016 18:37 #49029
by HappyHarry
nice one bud! glad to hear you got it working again
Time to create page: 0.680 seconds
- Devo 7 (NOT 7e) upgrade help
