Devo 7E + RX601 VS CC2500 PA LNA + DIY FRSKY 8CH
28 May 2016 10:00 - 28 May 2016 10:03 #49417 by DJDavid33
Hello I use a Devo 7E with the short circuit of diode CYRF6936 + antenna with a RX601.
I have a good disctance of reach (300m).
I would like to have more ...
I like to know if I my module "CC2500 pa LNA" + "DIY FrSky 8CH Receiver RX"
I have a greater distance? and how much ?
Thank you
Last edit: 28 May 2016 10:03 by DJDavid33.
28 May 2016 11:55 #49423 by Arakon
I've been out 880 meters with the CC2500 and a Frsky D4R before I got the very first RSSI beep.
As for the DIY receiver, that will depend greatly on the version. If it's one with PA/LNA, then you should be able to get the same kind of range as with an official FRsky receiver.
28 May 2016 14:12 #49434 by DJDavid33
Replied by DJDavid33 on topic Devo 7E + RX601 VS CC2500 PA LNA + DIY FRSKY 8CH
ok thank you for your response if I have 800 meters it will be the top.
that the RX is not expensive so that is why it interested me;)
www.banggood.com/DIY-FRSKY-8CH-Receiver-...FT-DHT-p-987247.html
28 May 2016 15:33 - 28 May 2016 15:40 #49438 by Cereal_Killer
Replied by Cereal_Killer on topic Devo 7E + RX601 VS CC2500 PA LNA + DIY FRSKY 8CH
DJD PLEASE do your own range check with that rx, it has neither PA nor LNA (PA = Power Amp, increases the range of the returned telemetey signal sent back by receiver to transmitter. LNA = low noise amp, increases the receivers listening ability to hear tx signal over noise floor)
There are cheap (under $20) diy frsky receivers that have PA/LNA or you can get a X4R for $25 shipped from the US.
$18 RX-F801
m.banggood.com/DIY-RX-F802-8CH-Receiver-...FT-DHT-p-989610.html
Last edit: 28 May 2016 15:40 by Cereal_Killer.
28 May 2016 18:19 #49445 by DJDavid33
ok I am from France I can not get us
but that yes:
www.banggood.com/DIY-RX-F802-8CH-Receive...FT-DHT-p-989610.html
thank you again for your help ;)
Time to create page: 0.314 seconds
