Range Test
- 92zb
30 May 2016 19:40 #49584
by 92zb
Range Test was created by 92zb
I am struggling to find out in what condition a Range Test in 7e is possible / not possible. It is so important for me and as I am new to this 2.4Hz system and the season of flying has just started. I have few cheap RX from Orange to a cheap £3.50 from BG. I searched every where could not find the answer. Thanks for your help.
- HappyHarry
30 May 2016 21:52 #49588
by HappyHarry
Replied by HappyHarry on topic Range Test
if you have done the range mod (or are using a module with a PA) then lower the power output to 100µW, that's sufficiently low for range tests
- Cereal_Killer
30 May 2016 22:54 #49594
by Cereal_Killer
Replied by Cereal_Killer on topic Range Test
Not that this applies to me, just curious [and it's on subject]...
With a stock (non-range modded) 7E does range check mode do anything?
- HappyHarry
30 May 2016 23:00 #49595
by HappyHarry
tbh I'm not sure, I can't remember if the power adjustment is only possible once you enable the relevant 'has-pa' line in hardware.ini
- 92zb
31 May 2016 12:00 #49635
by 92zb
Replied by 92zb on topic Range Test
I just changed "has_pa-cyrf6936 = 0" to "1" is it ok. Now the Range Test option is avaiable.
- Fernandez
31 May 2016 12:50 - 31 May 2016 12:51 #49637
by Fernandez
Replied by Fernandez on topic Range Test
I find that our rangetest or 100uW setting is not good for Range test, at least for the CC2500, we still output much to high power......
I use a diode RF detector for field strength and it still give significant signal, when using stock Frsky DHT-U in rangecheck mode my detector does not anymore indicate any RF.
This matches my field result, DEVO 7e Frsky in Rangecheck mode, I have to run far far and still keep the signal stay solid.......
I think wer have to disable fully the PA, to do rangecheck. However that than only check the RX antenna......
Last edit: 31 May 2016 12:51 by Fernandez.
- Thomas.Heiss
01 Jun 2016 07:55 #49707
by Thomas.Heiss
Replied by Thomas.Heiss on topic Range Test
Better try google search keywords - forum search and result list (posting instead of thread title) does not work that well: site:deviationtx.com dsmx range / 100uw 300uw 1mw / devo7e DSM range
www.google.de/search?q=site:deviationtx....s.heiss+1mw&start=10
Will give you tons of threads on topic...
Deviation output power 100mw = 100mw (test by vlad): www.deviationtx.com/forum/3-feedback-que...ut-power-150mw-100mw
DSMx genuine Spektrum receiver range tests 100uw/300uw/1mw: www.deviationtx.com/forum/protocol-devel...port?start=400#45377
Thomas
Thomas
Time to create page: 0.408 seconds
- Range Test
