Devo 10 Broken USB Before install Deviation...
- 6Axis
02 Jun 2016 07:49 #49811
by 6Axis
Devo 10 Broken USB Before install Deviation... was created by 6Axis
Hello everyone!
I'm new on the site of the great flexsible Walkera Devo transmitter.
Thanks for all the useful information that I
have gotten here from all contributors!
On my Devo 10 I do not get installed
new software because the mini USB plug
have fallen completely off (cold soldering ? )
Can someone be kind and show me solder points on the main board for new WIRE and external USB connector ?
Thank you in advance!
With best regards
6Axis
With best regards
6Axis
- 6Axis
03 Jun 2016 07:57 #49851
by 6Axis
Replied by 6Axis on topic Devo 10 Broken USB Before install Deviation...
Hi
Update
I am happy that found this discussion www.deviationtx.com/forum/6-general-disc...usb-connector-wiring
that led me on to this great site www.rcgroups.com/forums/showpost.php?p=34339267&postcount=2498
and believe it can be applied to Devo 10 also
Update
- udglab
03 Jun 2017 08:36 #62805
by udglab
Replied by udglab on topic Devo 10 Broken USB Before install Deviation...
Do you have solved the problem?....I have the same trouble now
- 6Axis
07 Jun 2017 04:50 #62864
by 6Axis
Yes please!
I soldered USB wire directly on motherboards and followed information that is
In the links above.
In the links above.
Time to create page: 0.602 seconds
- Devo 10 Broken USB Before install Deviation...
