Devo 7e Tank Control
03 Jun 2016 13:47 #49875 by trev502000
Devo 7e Tank Control was created by trev502000
hi i have a devo 7e with deviation firmware i have been playing with mixer setting for a twin motor tank style control for a robot with no luck just need a push in the right direction
i need to be able to control 2 motors on one stick to control forward back left and right what mixer config should i use?
thanks in advance
04 Jun 2016 08:57 #49909 by Nitro_123
Replied by Nitro_123 on topic Devo 7e Tank Control
Can you talk about how the default Tx does stuff ? Maybe that will help.
To control 2 motors on a stick you could use 2 channels and set the input to the same thing
So for example if channel 1 controlled one motor and channel 2 the other
you could go into the mixer and set the source for channel 1 as say throttle and the same for channel 2
Hope this helps.
04 Jun 2016 10:02 #49911 by HappyHarry
Replied by HappyHarry on topic Devo 7e Tank Control
most rc tanks use 2 sticks, one for each track
04 Jun 2016 10:13 #49913 by trev502000
Replied by trev502000 on topic Devo 7e Tank Control
ok i have a robot to compete in ant weight robot wars it is driven by 2 wheels both with independent motors and controllers i would like it to be in mode 2 with throttle controlling forward and rudder controlling left and right motion leaving the other stick for weapons
04 Jun 2016 15:37 - 04 Jun 2016 16:30 #49923 by Gerry
Replied by Gerry on topic Devo 7e Tank Control
I think a mix similar to elevon mixing for delta wing would work. Search the model config for some examples.
Edit. Attached combat wing config file
FFS (Forever Fixing Stuff)
Last edit: 04 Jun 2016 16:30 by Gerry. Reason: Add sample config
Time to create page: 0.607 seconds
