DIY 433mhz long range system
02 Jul 2016 19:06 #51259 by HappyHarry
Replied by HappyHarry on topic DIY 433mhz long range system
that's good to hear, hopefully one of the protocol guru's picks it up
02 Jul 2016 19:37 #51260 by victzh
Replied by victzh on topic DIY 433mhz long range system
How does he provide the firmware for these modules? Arduino source or hex files? If source, there is no need to reverse engineer, just use the Source, Luke.
03 Jul 2016 00:28 #51264 by Cereal_Killer
Replied by Cereal_Killer on topic DIY 433mhz long range system
Hex files that are loaded threw his companion app (ULRScc, not sure what cc stands for lol)
06 Jul 2016 21:04 #51371 by victzh
@Cereal_Killer - so did you test your boards? Do they work? Can I order the board and make the working ones myself? I need a working version before I subscribe to porting the protocol to Deviation.
07 Jul 2016 10:45 #51394 by Cereal_Killer
Yes! The board works and I got a very promising range test in low power mode (using only wire whip antennas) of >300 meters in a city environment but I would hold off on ordering till I make one more change over the weekend. Probably only take me 20 minutes of work but I can't promise I'll even get to it till the weekend.
The board as-is does work but I want to change the button resistor from an in line resistor to a pull-up and to add a buzzer output to D8. Again to confirm it does work but I feel this will make it more future proof.
07 Jul 2016 14:56 #51409 by nanoflyer
Replied by nanoflyer on topic DIY 433mhz long range system
Just ordered 3 boards from OSHPark and all the other stuff last week. I'll start with PPM from my 7E.
Is anyone making the Brotronics sub micro lrs rx?
07 Jul 2016 16:51 #51413 by victzh
RFM23BP source is no longer valid. Ebay have several options.
09 Jul 2016 06:50 #51478 by Elmtree
Replied by Elmtree on topic DIY 433mhz long range system
nanoflyer wrote: Just ordered 3 boards from OSHPark and all the other stuff last week. I'll start with PPM from my 7E.
When you say making do you mean prebuilt? If you're in the US FPVHeadquarters has it and the antenna. I have one on my most recent built.
09 Jul 2016 07:28 #51479 by nanoflyer
Thanks for the info.
02 Aug 2016 10:56 #52384 by HappyHarry
guys how long do oshpark orders usually take to arrive?
02 Aug 2016 12:06 #52385 by Cereal_Killer
Shipping notification usually takes 7- 10 business days from payment.
02 Aug 2016 12:50 #52386 by nanoflyer
Hi Cereal_Killer
I got 3 of the old v1 boards and wonder what's the difference to the v1.01?
Shall I order the v1.01 boards?
I have all the components waiting to be mounted.
02 Aug 2016 13:24 - 02 Aug 2016 13:28 #52387 by Cereal_Killer
Did you actually manage to get a real "v1.00" or do you mean you got one of the first revision (v012 / v013) boards? The actual V1.00 were only available for a few minutes, maybe an hour before v1.01 came out.
No need to upgrade, anything above v012 works fine. It's just very minor changes between them, they all run the same FW...
The ONLY difference is how the button works, on v1.01 the buttons resistor is a pull-up, on the V0.xx boards the resistor is simply inline between D10 and the button.
There won't be a big change till ULRS_TEENSY comes out then I'll do a V2.xx board to work with it.
Computer is STILL down (probably won't be able to afford a new one till black friday) so there are no revisions coming in the immediate future... :( again any boards you have now work.
Last edit: 02 Aug 2016 13:28 by Cereal_Killer.
02 Aug 2016 13:35 #52388 by nanoflyer
I got the one with 4 extra pads on the arduino side just above the led's
Well all things fine then, I'll head of into the workshop and mount the components.
Hope You'll get a new computer soon.
02 Aug 2016 21:27 - 03 Aug 2016 21:27 #52398 by HappyHarry
i just went to place a second order for another set of pcb's and the link to the boards is no longer working, have you taken them down bud?
[edit]
it's ok i found the link for the newer version on rcg, for anyone else the newest board version can be found here >> oshpark.com/shared_projects/2nCtZIbE
[/edit]
Last edit: 03 Aug 2016 21:27 by HappyHarry.
19 Aug 2016 21:18 #52913 by nanoflyer
@Cereal_killer
can i load openLRSng on the Ultimate lrs mini?
I have the brotronics Micro receivers with Openlrsng.
27 Aug 2016 18:57 #53150 by vampy
Replied by vampy on topic DIY 433mhz long range system
Cereal Killer why not using an Arduino with integrated USB www.aliexpress.com/item/1PCS-Promotion-F...ard/32531372300.html ?
27 Aug 2016 19:33 #53152 by HappyHarry
i'd guess because the components on the back wouldn't let it sit flush against the pcb for soldering
27 Aug 2016 19:51 - 27 Aug 2016 19:53 #53153 by vampy
Not important if u ask me.
Well I try it with integrated USB and solder the arduino with cables to the PCB.
Last edit: 27 Aug 2016 19:53 by vampy.
27 Aug 2016 19:58 #53154 by HappyHarry
well it would require a redesign/relayout of the pcb to allow for through holes to mount header pins to use the version of the arduino you linked, and perhaps he may do this in the future if it's something he wants? but due to the way the arduino is mounted on this current version it needs to be flat on the back side and have the sides of the pcb sanded down
Time to create page: 1.414 seconds
