Devo 8s for CC3D
06 Jul 2016 01:18 - 06 Jul 2016 01:20 #51340 by notlkk
Devo 8s for CC3D was created by notlkk
Has anyone done this? If so, could you share your settings and the Rx wiring? I'm trying to figure out if I can use my 8s for CC3D FC. I saw someone was able to use Devo 10 to hook up with CC3D so 8s should work, too.
I'd appreciate it if anyone could help.
Last edit: 06 Jul 2016 01:20 by notlkk. Reason: subscribed
06 Jul 2016 01:33 #51341 by mdmbc
Replied by mdmbc on topic Devo 8s for CC3D
What receiver are you using?
06 Jul 2016 20:39 #51370 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Devo 8s for CC3D
I did it with a Spektrum Sat. You will find any information of wiring here:
librepilot.atlassian.net/wiki/display/LP...a+Spektrum+Satellite
Attached: Model.ini for a Quad (Created on a Devo 8s)
08 Jul 2016 16:31 #51442 by notlkk
Replied by notlkk on topic Devo 8s for CC3D
Much obliged. I'll try it out.
08 Jul 2016 20:12 #51457 by alibenpeng
Replied by alibenpeng on topic Devo 8s for CC3D
The transmitter is mostly irrelevant in this. The important point is finding a receiver that is compatible to any of the protocols the Devo can use (with or without an additional RF module), that outputs PPM or PWM.
Using a Spektrum satellite is rather complicated compared to that, because the bind procedure seems to be a bit tricky, and not all FC firmwares that could run on the cc3d are equally good at implementing it. A regular Spektrum receiver (or clone) would be no problem, though, and will work with an unmodified Devo8 (with deviation firmware, obviously).
09 Jul 2016 10:55 #51483 by Sero
Replied by Sero on topic Devo 8s for CC3D
I use this FC, as it is plug and bind with Spektrum satellites, as it provides the proper plug, and most important, 3.3 volt.
30 Jul 2016 16:01 #52295 by notlkk
I'm thinking about using Walkera RX702. Would that work?
30 Jul 2016 20:59 #52300 by Fernandez
Replied by Fernandez on topic Devo 8s for CC3D
cc3d is still excellent flight controller, when you can flash it with betaflight 2.9 software and use betaflight configurator. It has good performance!. (much better than with openpilot/librepilot)
You can hook up spectrum satellite to the serial port of cc3d. Have to choose in the betaflight configurator that you use a spectrum satellite.
Time to create page: 0.117 seconds
